Quick test repaired Quark
- PDB
- Has thanked: 2 times
- Been thanked: 149 times
Quark came back from the US 2 weeks ago.
Cold an cloudy before noon, but suddenly around 12:30 clouds started to break. Still to cold (below 5°C) for the Quark, but decided to do a quick test anyway. Got it on temperature so the heater worked ok. Visually there was a lot of contrast in the image. (Had not seen that for long time).
So grabbed the laptop and the ASI-120 for a quick run, and shot 2 ser files + flat before clouds took over again. Not the best seeing for imaging,and no time to wait for good seeing. Sun 23° up in the sky.
The image is not really sharp, and too heavy processed, but the Quark looks promissing again ...
Paul
Paul
- Has thanked: 20779 times
- Been thanked: 10462 times
Re: Quick test repaired Quark
Glad the quark has returned mended! Glad you are getting some sun.
- Has thanked: 9307 times
- Been thanked: 6144 times
The seeing not great but still a valid image, Paul.
The nice part is that you are imaging again....
- Has thanked: 17970 times
- Been thanked: 8905 times
I'm glad you got one that works, the one they sent me back was an absolute joke
I look forward to sunnier days for you
- PDB
Thanks Franco and Alexandra.
Well, weather forecast for the coming days not good. We did not have many "good" days in December and January, a weather change would be really welcome.
P.
P.
Looks nice! Congratulates with a mended Quark.
BTW Does this image represents a full Quark FOV? Have you applied a flat field to this image?
- PDB
Hi Valery,
this was with the ASI 120MM but binned 2x to get bigger pixel size and not oversampling at f/25. (7.5 instead of 3.75) Noth resized in post processing but the crop in AS!3 made it a little bit smaller). Conditions were very bad and I had a lot of problems focusing when viewing on the laptop screen. A flat was applied (otherwhise there would have been a big dust donut)
While imaging conditions als deteriorated because of hazy clouds coming in.
Next test will be with a new 120mm/f8.3 (if the Sun ever comes back)
Paul
Paul
- PDB
Valery,
i now stacked a version Without flat and without the crop option in AS!3. So this is the full view on the ASI-120MM sensor.
Little bit of L&R an stretch in IMPPG and correct orientation. So this shows some darkening towards the left (but that is also direction of the limb)
And of course a big dust donut.
But flats can take care of this
Paul
Paul
- PDB
And here is an image taken today with the 120mm f/8.3 refractor (with Quark at f/35)
Still not really sharp but that is mainly due to:
- seeing conditions
- very bad focuser which I need to replace with something decent (wit 4200 mm focal lengt a good focuser is a must)
ASI 120 MM-S 2x binned against too much oversampling. Still some work ahead ...
regards,
Paul
- seeing conditions
regards,
Paul
Yes, good addition, the new quark seems to be a winner.
- PDB
Thanks Franco & Mark.
Still some work to do now on this refractor to get it fixed to the mount in good balance and a decent focuser without breaking the bank. But unfortunatelly "on a budget" and "astronomy" seem to be mutually exclusive. (and I should need to get a camera with an IMX174 sensor for that combination as well. €€€€..)
regards,
Paul
regards,
Paul
