Hi all,
Here is an image which I took last fall October 11.
It shows what can be seen on the absolutely bald sun if you look through a large aperture
telescope with narrow enough filter.
The telescope used is Celestron 11 280mm sperture equipped with a full aperture DERF filter
and a very simple etalon - Quark Chromosphere. The image was taken at a slight blue wing shift.
You can see here about a dozen of mini-flares (at least very hot spots) and a few small dark
filaments (small prominences projected at the disk) and numerous spiculaes far from the limb.
All these mini-ative objects are very short living and change very quickly. Very interesting
objects for time lapse imaging.
So, with a telecopes of appropriate size one can hunt for solar active events even during dead
season of the solar activity.
Activity on the absolutely bald sun through a 280mm aperture.
- Oct-11-2017-09h-26m--C11-Quark-Chr-blue-wing-3clc.jpg (491.66 KiB) Viewed 761 times
- Has thanked: 9149 times
- Been thanked: 6030 times
Re: Activity on the absolutely bald sun through a 280mm aperture.
A very interesting image, Valery, thank you.
- Has thanked: 20448 times
- Been thanked: 10254 times
It's very good Valery! I totally agree with you, look close enough and there is always something to see.
- Has thanked: 17672 times
- Been thanked: 8795 times
Fabulous Valery I know you are going to keep us entertained
- Been thanked: 4343 times
Hi Valery...
You caught a lot of small details, and proved that even when quiet there are features to tempt us.
Well done
Well done
- Has thanked: 8420 times
- Been thanked: 8173 times
Nice image, Valery. I'm looking forward to giving my large aperture kit a good run this spring.
