Check out a few homemade all-sky cameras I use (day & night)
WEBLINK:
http://re.apaaweb.com/all_sky_cameras.html
ALL-SKY CAMERAS
All-sky camera (Mintron 12V6HC-EX 1/2" CCD Starlight Camera, 4.5mm F/1.4 Computar lens)
All-Sky-Mirror (Canon 350D)
All-sky cameras (Mintron 12V6HC-EX 1/2" CCD Starlight Camera, 4.5mm F/1.4 Computar lens + Watec 902H, 4mm F/1.2 Computar TV lens)
All-sky-cameras. Watec 902H, Computar lens 3.8mm F/0.8, Watec 902H, fish-eye lens 1.7mm F/2. Homemade all-weather housings
Homemade all-sky cameras
- pedro
- Has thanked: 14 times
- Been thanked: 6689 times
- all_sky_20131102-002.jpg (378.37 KiB) Viewed 2141 times
Pedro Re'
- Been thanked: 4421 times
Re: Homemade all-sky cameras
Very impressive set of cameras Pedro
- pedro
- Been thanked: 171 times
Looks good Pedro that Mintron is what I use for Solar imaging or a version of it.I like the DSLR mirror set up only prob;em here is that it’s too humid.
Derek
Derek
- pedro
Thanks Derek
You can always heat the mirror. These traffic mirrors are relatively easy to find
- all_sky_20130216-010.JPG (472.65 KiB) Viewed 2112 times
- all_sky_20130216-007.jpg (621.27 KiB) Viewed 2112 times
Pedro Re'
- Has thanked: 17970 times
- Been thanked: 8904 times
- pedro
Thanks Alexandra
Hope you have some sun soon
Pedro Re'
- Has thanked: 20779 times
- Been thanked: 10462 times
Nice! What do they all get used for?
- Has thanked: 8543 times
- Been thanked: 8278 times
Nicely done, Pedro. What software do you run to capture 'events'?
Stu
Stu
- pedro
Thanks guys
Derek: a fan is all you need to keep the moisture away from the mirror
I use these cameras to control sky conditions when I'm imaging remotely (deep-sky)
During the day one of the cameras is always on to see if the sky clears when it's cloudy. I can go to the observatory and get everything running in about 10min.
Before both cameras where also used to record meteors and fireballs (UFO soft)
Pedro Re'
