Another one of AR2699. This was taken with the 80mm f/6 - Quark - Focal Reducer and ASI-120MM-S.
Did not use a tilt adapter, to see how bad NR's were going to be. They were there and after the flat still shining thru a bit. That was remover in software with Fast Fourier Transformation method.
Not as sharp as I would like, but this AR is to nice. It seems sharper on the left side, than on top right, and that puzzles me a bit. Looks as if the sensor or focal reducer are not lined up. Or is this just stacking with some better areas in some places of the image? Any ideas?
Rgrds,
Paul
2018/02/13 - AR2699
- Has thanked: 20828 times
- Been thanked: 10502 times
Re: 2018/02/13 - AR2699
Good shot! Not too sure about the top right, wait till better conditions before diagnostics.
- Been thanked: 8907 times
- Has thanked: 9327 times
- Been thanked: 6163 times
- Been thanked: 4434 times
Great capture Paul...great to see so many getting a chance to image it.
- PDB
- Has thanked: 2 times
- Been thanked: 149 times
Thanks Brian.
Today looks promising again (amazing we had more Sun showing this week than in the last 2 months), before it dissapears over the edge.
Paul
Paul
