halpha sun on March 9th
stef41
Post by stef41 » Fri Mar 09, 2018 3:40 pm
good morning, everyone,
the clouds came back late at night on the Albion plateau. I still managed to catch the sun in a very tiny lightening (before everything is gray!) (single 17s video! viva the 60img/s of the 178mm... and the SSD!)...)... as much to say that about the setting, there is only the strict minimum! I used an old flat to reduce the frame of the sensor, for the blow it added the interference fringes which were in the flat...
otherwise, fs60 with sm40 double stack, glasspath x1.25, BF10 and zwo178mm at 12h53 UT, reduced to 75%!
cordialy,
stéphane - france
robert
Re: halpha sun on March 9th
Post by robert » Fri Mar 09, 2018 8:15 pm
Shame about the rings. I don't think a flat is a good idea with a full disk?😞 lots of detail in the image.
Robert
2018 images https://www.flickr.com/photos/69734017@ ... 1234171714
Post by Carbon60 » Fri Mar 09, 2018 9:17 pm
At least you're seeing the Sun, Stephanie. Not a lot of it here to speak of.
Lunt LS60THa B1200 PTFT
DMK41, Basler acA1920-155
NEQ6 Pro-mount
stef41
Post by stef41 » Fri Mar 09, 2018 10:02 pm
Robert
flat is a good idea with a full disk with zwo178mm because : viewtopic.php?t=20973
cordialy
stéphane - france
robert
Post by robert » Sat Mar 10, 2018 7:37 am
Gamma at 50+ sounds better to me. I have seen patterns like that using other cameras at extreme settings.
Keep trying things☺
Robert
yltansg
Post by yltansg » Sat Mar 10, 2018 7:39 am
Hi Stephane,
Sometimes flats can help with getting rid of NR. Now I use an interference eliminator to get rid of the NR. It is more reliable.
Alfred
stef41
Post by stef41 » Sat Mar 10, 2018 11:59 am
NR = Newton Rings, I guess?
I have a problem with NR because of the glasspath. But it's gonna work out with a good tilt ring adjustment.
On the other hand, the 178mm pattern is more complicated to solve ( whatever the value of gamma )... except with a flat.
Here, the same picture without flat (with gamma=1 and gain=134):
cordialy
stéphane - france
Post by marktownley » Sat Mar 10, 2018 8:34 pm
Nice image Stephane!
Post by Montana » Sun Mar 11, 2018 1:03 pm
Super image, I hope you have some luck getting rid of the rings :bow :hamster: have you tried just letting the full disc drift across the image during capture, then Autostakkert will remove them.
rsfoto
Post by rsfoto » Sun Mar 11, 2018 4:25 pm
A real pity about the Newton rings
:shock:
Post by MapleRidge » Sun Mar 11, 2018 11:59 pm
Hi Stephane...
Nice to see your image...lucky to have caught it.
Users browsing this forum: Google [Bot] and 6 guests
