Springtime Sunshine - 25th March
- Been thanked: 10489 times
We went into British summertime today, and for once the forecast was considerably better than it has been. Skies were hazy but on such a solar drought I didn't care and was just nice to get out there in the garden and get back to what I like doing.
I started off with the Ed60 scope and white light wedge, nothing to see on a blank sun but nice to try this full disk rig out.
wl-full-disk-bw by Mark Townley, on Flickr
wl-full-disk-colour by Mark Townley, on Flickr
Swirching to CaK the scope showed a nice disk, not much happening but nice to see none the less, I still think I get better results with my 40mm f10 scope, but this 60mm comes a close second.
cak-full-disk-bw by Mark Townley, on Flickr
cak-full-disk-colour by Mark Townley, on Flickr
Next, the double stacked Quark in the ED60. Visually this is a nice performer, however for imaging the double stacked lunt50 has the edge, it will be a good combination when the seeing is cr@p and want to do medium scale shots of proms.
Ed60-FD-BW by Mark Townley, on Flickr
Ed60-FD-colour by Mark Townley, on Flickr
Moving to the Lunt50 single stack:
ha-full-disk-ss-bw by Mark Townley, on Flickr
ha-full-disk-ss-colour by Mark Townley, on Flickr
And double stacking:
ha-full-disk--ds-bw by Mark Townley, on Flickr
ha-full-disk--ds-colour by Mark Townley, on Flickr
I tried the ED80 with the Quark, but no real results, 60mm was the general limit of average seeing. I did try the HaT on the proms, and after dozens of exposures got this one:
proms-hat by Mark Townley, on Flickr
Spicules are blurred so gives an idea of conditions, either way nice to get out and image for a change!
Hope the weather is improving for you.
- Has thanked: 9319 times
- Been thanked: 6157 times
Re: Springtime Sunshine - 25th March
A very nice series, Mark. The seeing must have been decent, as you were able to get some good detail with the HaT. The best I could get with the HAT was this, that is not even close to your result.
- 111447-color.jpg (609.95 KiB) Viewed 1618 times
- Has thanked: 8559 times
- Been thanked: 8290 times
A good springtime session, Mark. Pity the Sun is so blank at the moment. I guess we'll just have to get used to it for a while.
- Has thanked: 9723 times
- Been thanked: 5773 times
Amazing images Mark
Very good Prominence shot
Thanks guys. The rest of the shots I took with the HaT were worse than the one you posted Franco, mind you I was using the native 4.3x telecentric on the Quark, I think next time I will give the HaT native 2.8x a go, it will give a wider bandpass on the etalon but for proms this might not be a bad thing and the smaller image scale should help with the seeing. The Easter break is getting closer so i'm hopeful of some clear skies at some point...
Very nice pictures Mark, especially the last one of the prom I had nice sunshine too but didn't get into the garden till the afternoon (had too many chores and dinner to cook). I would post mine if I could but I can't get Flickr to accept any of my images so I am stuck. Are you having any problems? it says that all mine don't look like an image and it refuses to upload them.
Thanks Alexandra, Flickr behaving for me...
- Been thanked: 4980 times
Mark:
The good thing is that you got all your solar gear out and started to image again.
Hope you get good weather this weekend.
In Mexico it is a Catholic weekenf feast, so I will try to image too.
Best wishes to all of you good friends,
Thanks Eric! I found another prom shot that came out OK. Decided to have a mess with some colour.
proms2 by Mark Townley, on Flickr
- Been thanked: 171 times
A productive session Mark and good comparisons.Waiting for summer time to finish here and all clouds here.Have a good weekend.
- Been thanked: 4427 times
Hi Mark...
Great images from this session...nice and sharp, too bad there was so little activity
The prom shots came out nicely.
Hi Mark,
These quiet sun days you obviously need a double stack in the CaK and a triple stack in H-a !!!
Images are nice, but the lack of notable details require more etalons to use.
I had been thinking pf triple stacking the Ha Valery.
