Solar Surface & Proms | HA, WL | Quark, Continuum | 120mm
MalVeauX
Post by MalVeauX » Sun Mar 25, 2018 4:50 pm
Hey all,
Quite the blank disc lately! But, I woke up to a lovely grouping of prominences on the limb. Weather is terrible, some clouds, and windy. Seeing was pretty bad actually too. Could barely get good surface spicules detail. But the proms came through, and that's what I really wanted. Even though its a solar minimum, there are still lovely things to see in the different wavelengths and hydrogen alpha always provides something to image or see, be it the surface itself and some features, or my favorite which are the mighty prominences.
Imaged with a 120mm F8.3 achromatic refractor and a Quark Chromophere for the Hydrogen Alpha views, and threw in a 0.5x focal reducer (on the camera nose) to change scale & FOV a little during some poor seeing. I tune mine to nearly all the way to the blue side (9 o'clock if I recall). For the white light, I used the same scope, with Baader Solar Film, Baader Solar Continum (540nm) and an Explore Scientific 3x Focal Reducer. ASI174MM is the camera I use for all this.
From my observatory I recently finished:
Setup:
Mount: Orion Sirius (HEQ5)
Imaging OTA: Celestron Omni XLT 120 + Linear Bearing GSO Focuser + 80mm Extension Tubes x 2 (I don't use a diagonal)
HA Filter: Quark Chromosphere
White Light: Baader Solar Film & Baader Solar Continuum (540nm) Filter
ERF: Baader UV/IR Cutter (in the focuser on the nose of my extension tubes)
Focal Extender: Explore Scientific 3x Focal Extender (only for White Light high resolution surface)
Focal Reducer: GSO 0.5x (to control scale & FOV when seeing is poor)
Software: SharpCap (capture), imPPG (decon & histogram stretching), Photoshop (all other edits); Colored in post
I captured 300 frames per sequence.
I stacked 31 images for virtually everything here except the prominences I stacked 41 (to reduce noise and increase S/N ratio for processing latitude).
Seeing was a solid 2 at best moments, 1 most of the time, with lots of low clouds passing through; I had to image through sucker holes.
ImageDSCF8252 copy by Martin Wise, on Flickr
Images:
Solar Disc in White Light; Void of SunSpots and no obvious Faculae
ImageSolarDisc_WL_03252018 by Martin Wise, on Flickr
Solar Surface in White Light; High Resolution, revealing some Convection Cells and minor Faculae fingers; B&W & Colored
ImageSolarSurface_WL_HR_BW_03252018 by Martin Wise, on Flickr
ImageSolarSurface_WL_HR_Color_03252018 by Martin Wise, on Flickr
Solar Surface & Prominences in Hydrogen Alpha; Focal Reducer used for scale/FOV during bad seeing; B&W & Colored
ImageSolarSurfaceProms_HA_Reducer_BW_03252018 by Martin Wise, on Flickr
ImageSolarSurfaceProms_HA_Reducer_Color_03252018 by Martin Wise, on Flickr
Solar Surface & Prominences in Hydrogen Alpha; High Resolution (poor seeing still); B&W & Colored
ImageSolarSurfaceProms_HA_BW_03252018 by Martin Wise, on Flickr
ImageSolarSurfaceProms_HA_Color_03252018 by Martin Wise, on Flickr
Astrobin data:
Re: Solar Surface & Proms | HA, WL | Quark, Continuum | 120mm
Post by Carbon60 » Sun Mar 25, 2018 5:33 pm
A very nice set of images, Martin.
Lunt LS60THa B1200 PTFT
DMK41, Basler acA1920-155
NEQ6 Pro-mount
Post by marktownley » Sun Mar 25, 2018 8:21 pm
You had a good run of images there Marty. Sounds like your seeing was the same as mine.
robert
Post by robert » Mon Mar 26, 2018 7:48 am
Great prominence shots
Robert
Derek Klepp
Post by Derek Klepp » Mon Mar 26, 2018 9:23 am
Nice set Marty.
Post by ffellah » Mon Mar 26, 2018 12:24 pm
Bruce Girrell
Post by Bruce Girrell » Mon Mar 26, 2018 12:43 pm
Nice work on the proms. I was trying to capture those guys yesterday too, but couldn't get anywhere near the detail that you have
Looking good
eroel
Post by eroel » Mon Mar 26, 2018 1:55 pm
Martin:
Beautiful session, sharp and clean images.
Post by Montana » Mon Mar 26, 2018 6:34 pm
Beautiful set of images and great presentation :bow :hamster: you are very lucky to have an observatory :)
Users browsing this forum: No registered users and 8 guests
