Hey all,
Quite the blank disc lately! But, I woke up to a lovely grouping of prominences on the limb. Weather is terrible, some clouds, and windy. Seeing was pretty bad actually too. Could barely get good surface spicules detail. But the proms came through, and that's what I really wanted. Even though its a solar minimum, there are still lovely things to see in the different wavelengths and hydrogen alpha always provides something to image or see, be it the surface itself and some features, or my favorite which are the mighty prominences.
Imaged with a 120mm F8.3 achromatic refractor and a Quark Chromophere for the Hydrogen Alpha views, and threw in a 0.5x focal reducer (on the camera nose) to change scale & FOV a little during some poor seeing. I tune mine to nearly all the way to the blue side (9 o'clock if I recall). For the white light, I used the same scope, with Baader Solar Film, Baader Solar Continum (540nm) and an Explore Scientific 3x Focal Reducer. ASI174MM is the camera I use for all this.
From my observatory I recently finished:
Setup:
Mount: Orion Sirius (HEQ5)
Imaging OTA: Celestron Omni XLT 120 + Linear Bearing GSO Focuser + 80mm Extension Tubes x 2 (I don't use a diagonal)
HA Filter: Quark Chromosphere
White Light: Baader Solar Film & Baader Solar Continuum (540nm) Filter
ERF: Baader UV/IR Cutter (in the focuser on the nose of my extension tubes)
Focal Extender: Explore Scientific 3x Focal Extender (only for White Light high resolution surface)
Focal Reducer: GSO 0.5x (to control scale & FOV when seeing is poor)
Software: SharpCap (capture), imPPG (decon & histogram stretching), Photoshop (all other edits); Colored in post
I captured 300 frames per sequence.
I stacked 31 images for virtually everything here except the prominences I stacked 41 (to reduce noise and increase S/N ratio for processing latitude).
Seeing was a solid 2 at best moments, 1 most of the time, with lots of low clouds passing through; I had to image through sucker holes.
DSCF8252 copy by Martin Wise, on Flickr
Images:
Solar Disc in White Light; Void of SunSpots and no obvious Faculae
SolarDisc_WL_03252018 by Martin Wise, on Flickr
Solar Surface in White Light; High Resolution, revealing some Convection Cells and minor Faculae fingers; B&W & Colored
SolarSurface_WL_HR_BW_03252018 by Martin Wise, on Flickr
SolarSurface_WL_HR_Color_03252018 by Martin Wise, on Flickr
Solar Surface & Prominences in Hydrogen Alpha; Focal Reducer used for scale/FOV during bad seeing; B&W & Colored
SolarSurfaceProms_HA_Reducer_BW_03252018 by Martin Wise, on Flickr
SolarSurfaceProms_HA_Reducer_Color_03252018 by Martin Wise, on Flickr
Solar Surface & Prominences in Hydrogen Alpha; High Resolution (poor seeing still); B&W & Colored
SolarSurfaceProms_HA_BW_03252018 by Martin Wise, on Flickr
SolarSurfaceProms_HA_Color_03252018 by Martin Wise, on Flickr
Astrobin data:
Solar Surface & Proms | HA, WL | Quark, Continuum | 120mm
- Has thanked: 1200 times
- Been thanked: 1390 times
- Has thanked: 8588 times
- Been thanked: 8324 times
Re: Solar Surface & Proms | HA, WL | Quark, Continuum | 120mm
A very nice set of images, Martin.
- Has thanked: 20940 times
- Been thanked: 10587 times
You had a good run of images there Marty. Sounds like your seeing was the same as mine.
- robert
- Has thanked: 4 times
- Been thanked: 1286 times
Great prominence shots
Robert
Robert
- Has thanked: 9387 times
- Been thanked: 6199 times
Nice work on the proms. I was trying to capture those guys yesterday too, but couldn't get anywhere near the detail that you have
Looking good
Looking good
- Been thanked: 5016 times
Martin:
Beautiful session, sharp and clean images.
- Has thanked: 18105 times
- Been thanked: 8941 times
Beautiful set of images and great presentation you are very lucky to have an observatory
