Hi:
Just returned from the rural observatory, took some reflections of the sun on the moon but seeing was not to par.
Anyway, the mosaic went through.
Hope you like it, it was taken with a 10" f/20 TEC Maksutov and the SKYnyx 2-2 with a 0.5x reducer at its nose, the seeing was changing every moment, it still was daylight time, the scope did not equalize in temperature, but if you open another window, you can see how it looks, there are more small craterlets inside craters.
Weekend days were not good, much haze and clouds.
Solar reflections from the 24th of March 2018.
- Been thanked: 4904 times
- Has thanked: 20424 times
- Been thanked: 10243 times
Re: Solar reflections from the 24th of March 2018.
Wow! That's good!
- Been thanked: 1575 times
Nice picture Eric of the moon - always good to see up close. Thanks, John W.
- Has thanked: 9144 times
- Been thanked: 6025 times
That is a great close-up mosaic, Eric ! It is probably the first one of this kind I see.
Mark, John and Franco, Thanks for the kind comments.
- Has thanked: 17666 times
- Been thanked: 8787 times
Wow! probably the best I have seen Eric, it looks super in another window at full res
Alexandra:
Thanks, I really liked it when I started postprocessing it.
Sometimes you do not expect a nice result when you see some parameters out of order.
Looks like my workflow for the sun works on the moon.
- Has thanked: 8415 times
- Been thanked: 8161 times
An amazingly good image, Eric.
Stu:
Thank you, the TEC Mak works nicely.
