G-Band and H-Alpha Images from Singapore (New images added)
- yltansg
- Has thanked: 1446 times
- Been thanked: 1423 times
The setup
G-Band with ARIES D-ERF on a C8
H-Alpha with Baader ERF on a 150mm OMNI XLT refractor
G-Band Image with ARIES D-ERF & G-Band on a C8
H-Alpha Image with Baader D-ERF on a 150mm Celestron OMNI XLT refractor
- robert
- Has thanked: 4 times
- Been thanked: 1274 times
Re: G-Band and H-Alpha Images from Singapore
Wonderful clear granulation, lovely
Robert
Robert
- Has thanked: 20424 times
- Been thanked: 10243 times
Really exquisite images Alfred. The granulation is some of the best i've seen. I envy your seeing and clear skies!
- Been thanked: 4340 times
Excellent images Alfred...well done
- Has thanked: 9144 times
- Been thanked: 6025 times
Granulation is spectacular, the Ha is excellent, Alfred.
Keep posting, please.....
- Been thanked: 4904 times
- yltansg
Thanks Robert, Mark, Brian, Franco and Eric for your kind comments.
Mark - the seeing was so so. I was pleasantly surprised to see the quality of the PP images.
- yltansg
Here is another G-Band image taken on the same day taken 1 minute earlier
Here is another one taken 2 minute later
- pedro
- Has thanked: 14 times
- Been thanked: 6576 times
Great resolution Alfred. Which filter did you use in front of the camera?
G-Band Image with ARIES D-ERF on a C8
Pedro Re'
- yltansg
Hi Pedro,
Yes, G-band images on granulations were taken with ARIES D-ERF and G-band on a C8
Seeing became worst today. No decent images
Alfred
- pedro
Thanks for your reply. I guess the G-band filter is from Edmund Scientific
Pedro Re'
Hi Alfred,
Great images with the C8 at the G-band ! These ones are among the best I ever saw with 8" telescopes.
Wish you more great seeing weather.
Stunning detail Alfred! I can only hope for conditions this good!
- yltansg
Hi Pedro,
The G-Band filter is from Edmund Optics. It is a 25mm 430/10nm filter. I wasn't able to find a suitable casing for it to be "converted" to 1.25 inch. This is my improvisation - I used Blu Tack (useable plastic adhesive) to hold it in a Mallincam IR blocking cell. The IR blocking filter works well with the 430nm filter to produce fine granulations provided there is fair seeing.
- pedro
Thanks for your reply Alfred. I have to get one of these
Pedro Re'
Are you using a SSM Alfred?
- yltansg
Hi Mark,
I have a SSM and also Genika & Basler But have just not gotten down to use the SSM to control acquisition with Genika.
Alfred
- yltansg
Using the 3-Band AIRES D-ERF & Celestron C8, I reconfigured it as follows:
Over time I have collected 5 PST etalons which I wanted to use on this D-ERF and also a 14" ARIES D-ERF:
Had 2 runs with 1 etalon in extremely poor seeing:
Re: G-Band and H-Alpha Images from Singapore (New images added)
You have a lot of PST etalons Alfred
- Has thanked: 17667 times
- Been thanked: 8787 times
WOW!!! the granulation is to die for
- Has thanked: 8415 times
- Been thanked: 8161 times
Wonderful images, Alfred. Superb granulation.
- yltansg
Thanks Alexandra and Stu for your compliments. Some times I have this feeling it is easier to get the granulations on the ARIES DREF-C8-GBand filter than high-resolution H-Alpha images with ARIES DERF-C8-PST etalon. But thinking about it, I usually do G-Band imaging when seeing is good. I must make the change so I can test and rank their quality.
Mark - you mentioned - [You have a lot of PST etalons Alfred ]
I am trying to find very good PST etalons for the ARIES14" D-ERF that will be delivered soon
Alfred
Alfred
- Ronnie_Clayton
- Has thanked: 10 times
- Been thanked: 130 times
Your H-Alpha images are awsome, but your G-Band images are absolutely amazing!!!!!
Ronnie
Ronnie
- yltansg
Hi Ronnie,Ronnie_Clayton wrote: ↑Sun Apr 08, 2018 12:39 am Your H-Alpha images are awsome, but your G-Band images are absolutely amazing!!!!!
Ronnie
The better H-Alpha image was from a 150mm refractor fitted with a 160mm ARIES D-ERF, taken at 11:50am local time. Here are two more images taken on the same day using the same setup:
Taken at 9:21am
Taken at 9:28 am local time
Alfred
- Been thanked: 171 times
A great session Alfred and thanks for all the feed back with all the various filter types.
Regards Derek
Regards Derek
- yltansg
Derek and All,Derek Klepp wrote: ↑Sun Apr 08, 2018 9:29 am A great session Alfred and thanks for all the feed back with all the various filter types.
Regards Derek
I must thank everyone for their generous sharing which has made my learning journey smooth and fun. Hence I will make it a point to chip in as well.
Alfred
Alfred, can you describe your sharpening routine with the granulation shots please?
- pedro
I'm also interested in your image processing routines and how many images you combine (I guess less than 10)
Pedro Re'
- yltansg
Hi Pedro and Mark,marktownley wrote: ↑Sun Apr 08, 2018 12:58 pm Alfred, can you describe your sharpening routine with the granulation shots please?
My processing:
a. Step 1: I use AS!2 to stack about 180 to 200 frames from a recording of about 4000 frames.
b. Step 2: Next I use the LR deconvolution and Unsharp masking in ImPPG to post process the stacked image.
c. Step 3: The final step is to do noise reduction first with Topaz Denoise followed by other processing in PS (e.g. unsharp mask, contrast adjustment, level, curve stretch etc). I find doing the Topaz Denoise a crucial step before final PS pp.
As for PS processing, it is an art thing - just do different tweaks to get desired effects
To All - please share your sharpening routine. I would like to learn from you too.
Alfred
- yltansg
Hi Pedro,
I notice that Christian stack very few images. I have tried it but the outcome was poor. For my recordings and processing, I need to stack more than 130 frames to get sharp granulations. I think the secret to stacking fewer frames is in the way the post processing is done. Must learn it from Christian.
Alfred
The G band granulation is very sharp!
Great images
Great images
- Ronnie_Clayton
WOW, incredible h-alpha images Alfred
Congratulations!
Congratulations!
- yltansg
Thanks Bruce and Ronnie for your kind comments. I have re-configured the C8 for H-A imaging. I will not be doing G-Band images for the time being.
