Today's SUN (20180407) | SM90II first light
- Been thanked: 6696 times
WEBLINK:
http://re.apaaweb.com/sun_h_alpha_2018-04.html
Finally a few images with the LUNT152 + CORONADO SM90II
It seems that this etalon works better with high focal ratios (F/10)
IMAGING SETUPS
IMAGING SETUPS
SUN (20180407). H-alpha DISK & PROMS (09:30 UTC). LUNT152, SM90II, BF30, PGR GRASSHOPPER 3 GS3-U3-28S5M, two-pane mosaic
SUN (20180407). H-alpha DISK & PROMS (09:30 UTC). LUNT152, SM90II, BF30, PGR GRASSHOPPER 3 GS3-U3-28S5M, two-pane mosaics
SUN (20180407) H-alpha DISK & PROMS (08:30 UTC). LUNT60, BF30, PGR GRASSHOPPER 3 GS3-U3-28S4M
SUN (20180407) H-alpha DISK & PROMS (08:30 UTC). TV101 F/5.4, SM60, BF30, PGR GRASSHOPPER 3 GS3-U3-28S4M
SUN (20180407) CaK PROMS (08:30 UTC). TV101 F/5.4, LUNT 1200 CaK Module, PGR GRASSHOPPER 3 GS3-U3-28S4M
SUN (20180407) WL, CaK & H-alpha (08:30 UTC). TV101 F/5.4, LUNT 1200 CaK Module, SM60, BF30, PGR GRASSHOPPER 3 GS3-U3-28S4M
WEBLINK:
IMAGING SETUPS
IMAGING SETUPS
Re: Today's SUN (20180407) | SM90II first light
Hi Pedro,
A front mounted etalon works equally with different F/D of a scope. If you see the improvement - this is because the blocking filter works better in a slower F/D cone - it's bandwidth can widens with fast F/ratios and narrows with slower F/D - as the result you see the system overal performance. Several years ago I read this from Andy Lunt and I also noticed this with my first etalon 90mm Codonado Isle of Man. So, may be it is worth to try a weak barlow lens in a front of BF30 filter making equal F/D slower - about F/15-20.
This etalon is not that narrow (or may be not perfectly in band) but delivers a very uniform picture. I believe that with the Lunt 152 equipped also with it's native etalon, this SM90II will give outstanding DS pictures.
Thanks Vallery
My old Pre-Meade SM90 (that I sold unfortunately) worked fine with my TV101 F/5.4
With the SM90II it seems that I only have good images (on band) with longer focal ratios. I will try the barlow as soon as I have something to image (AR or prom)
I also plan to use it as a double stack etalon (LUNT152 Ha + SM90II)
regards
regards
- Been thanked: 8907 times
Very quiet, but the filament is still a nice target
Thanks Alexandra
best regards from Portugal
Thanks again Eric
abrazo
abrazo
- Been thanked: 4981 times
Pedro:
Nice session and presentation as always.
Abrazo,
Abrazo,
- yltansg
- Has thanked: 1455 times
- Been thanked: 1444 times
- Ronnie_Clayton
- Has thanked: 10 times
- Been thanked: 130 times
Great pics Pedro, congratulations!!
Your collection of solar equipment is a dream .
Ronnie
Ronnie
- Been thanked: 4434 times
Great images from this session Pedro
- Has thanked: 8559 times
- Been thanked: 8297 times
Nice set of images, Pedro. Great first light.
- Been thanked: 171 times
Definitely a different look Pedro I do look forward to the double stacking edition.
Thanks a lot guys
- Has thanked: 20828 times
- Been thanked: 10502 times
Very good Pedro! That 90mm DS setup should allow you some close up views of any more features we get.
Thanks Mark. I will try the DS next time. Unfortunately there are not many features to image
