AR2706 / 20-04-2018 - update
Posted: Fri Apr 20, 2018 12:20 pm
Small image of AR2706 today.
Skywatcher 120 f/8.3 with the new Baader Diamond Steeltrach focuser mounted (still in manual focus) and a new 2" 35nm Baader H-Alfa filter.
(mounting the steeltrack was not that easy. Synta had painted the inside flange , so it did not realy fit. Some sandpaper was needed to clean the flange)
Anyway, here a quick result with the ASI102MM (with focal reducer) ROI to het 330 FPS. (seeing not so great)
