AR12706 High Res in H-a 280mm SCT + ARIES DERF
Hi all,
Today was a clear transparent sky with a moderate seeing condition.
Here is the best image out of dozen I have recorded and processed.
280mm F/10 SCT has been used with the ARIES 295mm full aperture two bands filter.
The AR12706 was moderately active during these recordings. Several small mini-active
areas were seen on the sun disk. I will try to process their images and if they will come out
OK, I will add them here later.
Thanks for looking.
Thanks for looking.
- AR12706-04-21-2018-UT07h-26m-280mm-ARIES-295mm-DERF-QK-3clc.jpg (477.71 KiB) Viewed 1971 times
- banjo
- Has thanked: 2107 times
- Been thanked: 2887 times
Re: AR12706 High Res in H-a 280mm SCT + ARIES DERF
sorry for my English translators google
- Has thanked: 8559 times
- Been thanked: 8297 times
So much detail. Very nice indeed, Valery.
- Has thanked: 20828 times
- Been thanked: 10502 times
Super close up Valery!
Thanks banjo, Stu, Derek and Mark for your kind words.
I hope to post more pictures of this excellent AR12706.
- Ronnie_Clayton
- Has thanked: 10 times
- Been thanked: 130 times
OMG Valery
incredible picture, congratulations!!!!
- pedro
- Has thanked: 14 times
- Been thanked: 6696 times
Great image Valery
Pedro Re'
Hi Valery. Remind me what camera you are using here? What is the pixel size? You're using ROI to get down to the ~1300x900 frame size - how many fps with this?
Thanks, Mark
Thanks, Mark
Hi Mark,marktownley wrote: ↑Tue Apr 24, 2018 4:04 pm Hi Valery. Remind me what camera you are using here? What is the pixel size? You're using ROI to get down to the ~1300x900 frame size - how many fps with this?
Thanks, Mark
I do use the Basler 1920-155 camera with it's maximal fps (full size) of 160fps.
I do use ROI typically with 1450x1000 or 1500x990 and depends of the exposure time I can get up to 200fps.
With this particular image, if the memory serves me well, the fps were about 190-200.
- GreatAttractor
- Has thanked: 748 times
- Been thanked: 757 times
What a wonderful image. If you use SSM, I'm curious what was the indicated seeing value during this capture.
Ehh, this tiny thing is excellent only in >200 mmI hope to post more pictures of this excellent AR12706.
