Hi All,
Summer came briefly here in the UK (and went again!), however last week was late nights at work and not able to image as I would in the early evening. However friday was able to get off a bit earlier and squeeze in a bit of imaging before heading off on the boat for the weekend. Seeing was ropey at 5pm but got some shots in; first off the full disk with the 40mm f10 scope somewhere around f13.
cak-fd-bw by Mark Townley, on Flickr
cak-fd-colour by Mark Townley, on Flickr
Then upping the scopes, the ED80 but stopped down to 60mm at 600mm focal length.
cak-60-bw by Mark Townley, on Flickr
cak-60-colour by Mark Townley, on Flickr
Then some Ha full disks, which i'm not happy with, but more on that later: First off the single stacked lunt50:
ss-fd-bw by Mark Townley, on Flickr
ss-fd-colour by Mark Townley, on Flickr
Then the double stack version:
ds-fd-bw by Mark Townley, on Flickr
ds-fd-colour by Mark Townley, on Flickr
However my favourite shot was the active region with the ED80 and double stacked Quark:
ar12706-close-bw by Mark Townley, on Flickr
ar12706-close-colour by Mark Townley, on Flickr
I have a few more possibly, need to double check my files. Anyway, head off on the boat for a couple of days and fast forward to sunday afternoon and some fleeting gaps in the clouds. Remember I said I wasn't happy with my disks from the lunt 50 - lots of glow and soft images; well visually with a wide field or low power eyepiece it is quite easy to see a bright offset circle of glow overlapping the field of view. A reflection; so I set about to find it and hopefully deal with it. I'm using a Coronado BF15 blocker instead of the Luntb600 as this has a shorter optical path and stops the complications with imaging with the native Lunt setup. Well said reflection was from the back of the ITF filter on the blocker and somewhere on the innards on the scope, this was confirmed by removing the ITF and also rotating the blocker. I tried a circular polariser on the nose of the blocker and hey presto a black sky background and more contrast on the disk albeit at the expense of image brightness. It also did away with uneven brightness across the disk which was annoying me! The result is much better I think.
fd-ha-bw by Mark Townley, on Flickr
fd-ha-colour by Mark Townley, on Flickr
Needless to say the clouds have now returned. Hope you like them.
Some Sun From The Last Couple of Days
- Been thanked: 10248 times
- Has thanked: 9145 times
- Been thanked: 6027 times
- robert
- Has thanked: 4 times
- Been thanked: 1274 times
Re: Some Sun From The Last Couple of Days
Looking good
Robert
Robert
- Been thanked: 4904 times
Mark:
Without doubt, you had some fun during those days, really nice images.
Send my regards from N.Y. after meeting Franco and Brian at NEAF.
A very nice series of images, Mark. Thanks for sharing.
Also a good tips about the using a circular polarized with BF filter.
- Has thanked: 8418 times
- Been thanked: 8165 times
A really nice set of images, Mark.
- Been thanked: 171 times
Well done with problem solving Mark.Heading into Autumn here so hopefully a bit moeSun time albeit shorter days.
- yltansg
- Has thanked: 1446 times
- Been thanked: 1423 times
Hi Mark,
They are all great images. The one on AR12706from the double quark is especially beautiful
Alfred
Alfred
