AR12706 in a Single and a Double stack modes through my 280mm scope.
Hello, friends
Here are the results of my April 22 morning imaging session with my trusty 280mm SCT equipped with the ARIES full aperture 295mm two bands dielectric energy rejection filter.
I have imaged the sun with single and double stacked etalons. However the pictures are much more similar than this can be seen in other etalons stacking or SS.
The seeing was mostly poor that morning and I were able to take only a very few images with good resolution.
Thanks for looking.
Thanks for looking.
- AR12706-04-22-2018-UT07h57m-280mm-ARIES-295mm-DERF-DS-etalon.jpg (291.26 KiB) Viewed 1998 times
- AR12706-04-22-2018-UT07h40m-280mm-ARIES-295mm-DERF-SS-etalonL.jpg (493.47 KiB) Viewed 1998 times
Re: AR12706 in a Single and a Double stack modes through my 280mm scope.
Hi Val,
Thanks for your high estimation of my hamble efforts.
Hope you will have good weather for solar imaging. Now is excellent AR12706 in it's best position.
- Has thanked: 9144 times
- Been thanked: 6025 times
Very interesting, Valery. The second one, single stack, seems to be sharper that the first one.
Both great.
Both great.
- Has thanked: 9401 times
- Been thanked: 5568 times
WOW what dramatic Images and incredible high Resolution
Beautiful! Is the doublestack image a crop?
And another question: although the regular advice is to set Gamma at neutral (and I understand why) I sometimes find that turning the Gamma down when imaging makes it easier to process the image to a really good one with a lot of details. Off course the reason could be my lack of processing skills. What is your experience? And do you set gamma at neutral when imaging? Thanks in advance, Bart.
- Been thanked: 4340 times
Valery...
Excellent images, with a nice comparison of SS vs DS modes. Your efforts from capture through processing have produced superb results!!!
- Has thanked: 20435 times
- Been thanked: 10243 times
These are excellent Valery!
- Been thanked: 2713 times
Hello Valery,
The contrast of your etalons is impressive !
Your SolSp RG 0,3A is far better for imaging and even better for visual, I believe.christian viladrich wrote: ↑Thu Apr 26, 2018 10:21 am Hello Valery,
- Been thanked: 4904 times
Valery:
Super HR shots.
Super HR shots.
- Has thanked: 8415 times
- Been thanked: 8161 times
Amazing images, Valery. I'd be delighted with either of these. superb.
