Very interesting Mark, thanks for the update
Please keep us posted. I have some bad experiences with double stack etalons...
Thermal Acclimation of My Lunt50
- pedro
- Has thanked: 14 times
- Been thanked: 6754 times
- Has thanked: 9828 times
- Been thanked: 5828 times
Re: Thermal Acclimation of My Lunt50
Hi Mark,
Interesting and good animation.
Rainer
Rainer
- Has thanked: 20962 times
- Been thanked: 10593 times
The more I experiment with this scope the more i'm convinced the etalon sits loose in the chamber it is housed in. You can definitely hear a 'moving part' in the etalon chamber and it can only be the etalon. The fact I can get the sweetspot as a band implies the etalon is tilted relative to the normal. The fact that I can alter the relative tuning by the angle the scope sits at - ie rotating it in the tube rings just screams loose etalon sitting in the chamber.
I couldn't get it uniformly on band at all this evening and was saying lots of bad words. I did try triple stacking it with another 50mm etalon with results below.
HA-fd-ts-bw by Mark Townley, on Flickr
Not even.
I'm now exploring a few options here, as in it's current form this pressure tuned Lunt simply does not do it for me - too much faffing around to make it work. Firstly disassemble, reassemble and diagnose the LS50 to see what can be improved. Secondly looking at LS50 etalons with a view to double stacking with external etalons for more even larger sweetspot - 50mm etalons are pretty cheap at the moment so I think I will do Valerys trick and shop around for the best ones.
Not even.
I got the lens spanner out last night and tightened down the cell on the ERF, so will see if that helps.
- Bob Yoesle
- Has thanked: 543 times
- Been thanked: 812 times
Looks to have great contrast when stabilized Mark. excellent imaging BTW!
Makes sense. This is why the etalon is flopping around...
Next steps with this, the etalon chamber is coming apart and i'm going to do a rebuild / re-engineer as needed.
