After a drought of many weeks and getting back from NEAF here today's Sun in Full disk made out as usual from 9 images.
Best seen in new tab or window
Full disk Sun 27-04-2018
- Has thanked: 9414 times
- Been thanked: 5578 times
- Been thanked: 4340 times
Re: Full disk Sun 27-04-2018
That's a very sharp FD image Rainer...well done
- Been thanked: 10247 times
That FD is excellent Rainer!
- Been thanked: 171 times
Hi and thanks everybody,
BTW the sky looked like in the image. Looks like the cloud filter helps
As you know I bought a Daystar Quantum PE 0.4 angström filter at NEAF 2018 and while talking to Jen Winter, Owner of Daystar and showed her my Coronado Double stack images she evaluated the image quality at about 0.4 angström based on the details.
Another interesting thing are the gradients visible in the small reduced images. I measured the median inside of that two marked circles and the difference is from the left 185 to the right 173 only 12 steps seems to be for us a huge difference
I then made an artificial flat with the center image of the mosaic.
applied it on the original image
and the flattened result looks like this
Then I measured the same spots again
Normal Flattened
145 173
156 181
164 187
152 178
131 162
Now my dilema is. ¿ should I flatten in future or not ? it is a lot of work
Normal Flattened
145 173
156 181
164 187
152 178
131 162
- Been thanked: 4904 times
Rainer:
The 9 piece mosaic should be better with flattened parts.
Abrazo,
Abrazo,
Thanks for the update. Flatting mid disk and applying this to all panes should get rid of your gradient Rainer.
