H-alpha with 250 mm RCT
- Has thanked: 8558 times
- Been thanked: 8290 times
A little sunshine this morning allowed me to trial my 250 mm RCT Frankenscope mod with a Lunt 35 Ha telescope at the rear and an internal collimating lens feeding the Lunt Etalon. The sky was clear and blue, but the seeing was not great for a scope of this aperture, so I wasn't expecting things to be optimal. My main interest this morning, however, was to check that everything worked together, as I've made a few changes since I last tried this combo. Things looked awful at first, but after a few tweaks to achieve proper alignment between the RCT and the Lunt I finally managed to obtain an image worth capturing.
Again, the seeing was pretty bad and really quite shocking when I reviewed the SER file. Still, AS3 did its magic as did Imppg to at least pull something from the mess. Overall I think is looks very promising. I just need to be ready for when the conditions are more favourable.
20180429_Ha_250RCT by Stuart Green, on Flickr
Thanks for looking.
Thanks for looking.
- GreatAttractor
- Has thanked: 747 times
- Been thanked: 757 times
Re: H-alpha with 250 mm RCT
Very promising indeed, Stu! Looking forward to when you get better conditions.
- krakatoa1883
- Has thanked: 153 times
- Been thanked: 496 times
Interesting result, it seems the scope is capable of really high resolution. Where is the ERF located ? Is it a front one ?
Raf
- Been thanked: 4427 times
Hi Stuart...
The image looks good under the conditions you describe. These large scopes need above average conditions by the looks of it. A year on and I'm still not overly happy with my 25cm SCT project but I hope to get more time to work on it this spring.
Keep us posted on your efforts and results.
- Been thanked: 4980 times
- Has thanked: 9319 times
- Been thanked: 6157 times
Yes, promising, Stu. I know how you feel after having gone out twice this year with the 203mm HaT and having not much to show for it due to bad seeing.
I look forward to seeing your first results with good conditions...(and mine too)
- Been thanked: 171 times
- Has thanked: 20813 times
- Been thanked: 10487 times
Nice shot Stu. I've not been able to get my HaT out so far this year because of the weather.
Many thanks, Guys.
I guess we're pushing the limits with these scopes, hoping for and requiring great conditions for optimal performance; conditions that, regrettably, are all to infrequent.
Raf, the scope employs a full size front mounted ERF from Valery.
Yup, sadly this is true!
- Been thanked: 2725 times
It looks promising. The constrast appears good given the conditions.
Thanks Christian.
- banjo
- Has thanked: 2100 times
- Been thanked: 2878 times
Hello,
good results, given the current bad weather.
I look forward to the continuation with a beautiful sky
Paul
Paul
- Ibbo
- Has thanked: 2443 times
- Been thanked: 1650 times
Wow! I'd be really happy with an image like that. Very smooth and fine detail
I am hoping to do some WL with the C11 this weekend if the Sun decides to shine early in the morning (yes a miracle needed there).
- pedro
- Has thanked: 14 times
- Been thanked: 6691 times
Nice Shot Stu, please keep us posted
Pedro Re'
