Not very good news about Solar Minimum
rsfoto
Has thanked: 9811 times
Been thanked: 5823 times
Post by rsfoto »
Today in www.spaceweather.com is an interesting article
I copied it here in case tomorrow it is not there anymore
SUNSPOTS VANISHING FASTER THAN EXPECTED: Sunspots are becoming scarce. Very scarce. So far in 2018 the sun has been blank almost 60% of the time, with whole weeks going by without sunspots. Today's sun, shown here in an image from NASA's Solar Dynamics Observatory, is typical of the featureless solar disk:
The fact that sunspots are vanishing comes as no surprise. Forecasters have been saying for years that this would happen as the current solar cycle ("solar cycle 24") comes to an end. The surprise is how fast.
"Solar cycle 24 is declining more quickly than forecast," stated NOAA's Space Weather Prediction Center on April 26th. This plot shows observed sunspot numbers in blue vs. the official forecast in red:
"The smoothed, predicted sunspot number for April-May 2018 is about 15," says NOAA. "However, the actual monthly values have been lower."
"Official" forecasts of the solar cycle come from NOAA's Solar Cycle Prediction Panel–a group of experts from NOAA, NASA, the US Air Force, universities and other research organizations. They have been convening at intervals since 1989 to predict the timing and intensity of Solar Max. The problem is, no one really knows how to predict the solar cycle. The most recent iteration of the panel in 2006-2008 compared 54 different methods ranging from empirical extrapolations of historical data to cutting-edge supercomputer models of the sun's magnetic dynamo. None fully described what is happening now.
It's important to note that solar minimum is a normal part of the sunspot cycle. Sunspots have been disappearing (or nearly so) every ~11 years since 1843 when German astronomer Samuel Heinrich Schwabe discovered the periodic nature of solar activity. Sometimes they go away for decades, as happened during the Maunder Minimum of the 17th century. We've seen it all before. Or have we….?
Researchers are keeping a wary eye on the sun now because of what happened the last time sunspots disappeared. The solar minimum of 2008-2009 was unusually deep. The sun set Space Age records for low sunspot number, weak solar wind, and depressed solar irradiance. When the sun finally woke up a few years later, it seemed to have "solar minimum hangover." The bounce-back Solar Max of 2012-2015 was the weakest solar maximum of the Space Age, prompting some to wonder if solar activity is entering a phase of sustained quiet. The faster-than-expected decline of the sunspot cycle now may support that idea.
Newcomers to the field are often surprised to learn that a lot happens during solar minimum: The sun dims, albeit slightly. NASA recently launched a new sensor (TSIS-1) to the International Space Station to monitor this effect. With less extreme UV radiation coming from the sun, Earth's upper atmosphere cools and shrinks. This allows space junk to accumulate in low Earth orbit.
Above: A neutron bubble chamber in an airplane 35,000 feet above Greenland. Spaceweather.com and Earth to Sky Calculus are flying these sensors to measure aviation radiation during solar minimum. [more]
The most important change, however, could be the increase in cosmic rays. Flagging solar wind pressure during solar minimum allows cosmic rays from deep space to penetrate the inner solar system. Right now, space weather balloons and NASA spacecraft are measuring an uptick in radiation due to this effect. Cosmic rays may alter the chemistry of Earth's upper atmosphere, trigger lightning, and seed clouds.
Air travelers are affected, too. It is well known that cosmic rays penetrate airplanes. Passengers on long commercial flights receive doses similar to dental X-rays during a single trip, while pilots have been classified as occupational radiation workers by the International Commission on Radiological Protection (ICRP). Ongoing measurements by Spaceweather.com and Earth to Sky Calculus show that dose rates at cruising altitudes of 35,000 feet are currently ~40 times greater than on the ground below, values which could increase as the solar cycle wanes.
Solar minimum is just getting started. Stay tuned for updates.
Has thanked: 9383 times
Been thanked: 6199 times
Re: Not very good news about Solar Minimum
Post by ffellah »
How cheerful, Rainer ! Now I am thinking of changing hobby for the next few years and coming back towards the solar maximum... :D
Has thanked: 156 times
Been thanked: 893 times
Post by Valery »
ffellah wrote: Thu May 03, 2018 12:23 am How cheerful, Rainer ! Now I am thinking of changing hobby for the next few years and coming back towards the solar maximum... :D
Franco,
If to be honest, in comarision to the sun, all other objects we can observe on the sky, are literally dead. Where can we observe the dynamic? Comets, Jupiter, rarely Saturn storms and martian dust storms, very diffuse high clouds in the Venus' atmosphere (in UV), supernovaes in distant galaxies. Lunar face monthly changes in the same sequence as before.
Did I forget something?
The solar minimum is not that dead time on the Sun. Prominences theirselves worth all other "dynamical" objects. With a scope 7" and larger there are a lot, really a lot to see what changing on the sun every hour. "Mini-flares", mini-flux areas, small dark filaments, spiculaes. Constant changes in the white areas visible in the Ca-K line. All these details are not much less impressive than sun spots as seen in small telescopes.
With my C11, I need to limit the cadence of the prominences movie records to only 10sec due to fast changes, and to about 15sec when imaging spiculaes.
Valery.
Post by ffellah »
Valery, it was a joke :lol:
Bob Yoesle
Has thanked: 543 times
Been thanked: 811 times
Post by Bob Yoesle »
This is nothing new, and has been in the science media for many years:
http://www.skyandtelescope.com/astronom ... 100-years/
It is also opening some interesting science theories about our star, and as Mr. Spock would say... "fascinating."
https://www.ras.org.uk/news-and-press/2 ... ble-dynamo
rsfoto
Post by rsfoto »
Bob Yoesle wrote: Thu May 03, 2018 2:41 pm This is nothing new, and has been in the science media for many years:
Hi Bob,
Thanks and looking and reading this one could ask,
Where is global warming made by humans ?
:movie
Has thanked: 20940 times
Been thanked: 10587 times
Interesting articles everyone!
Bob Yoesle
Hi Rainer,
Unfortunately, global warming will be here to stay no matter what the sun does:
https://www.skepticalscience.com/mini-i ... wrong.html
https://www.washingtonpost.com/news/ene ... d6ed74c68b
Derek Klepp
Been thanked: 171 times
Post by Derek Klepp »
Thanks All interesting reading on a cloudy Saturday here.
