First Light with Celestron C11
Has thanked: 4058 times
Been thanked: 1658 times
This morning a miracle happened, it was totally clear blue sky early in the morning. Finally I have handles on the C11 although I still needed the hubby's help as I didn't have a third hand to tighten the clasp screws but he managed that fine :)
ImageCelestron C11 by Alexandra Hart, on Flickr
I didn't expect to see anything but I tried 2x Barlow and the Baader solar film ND3.8 and the Baader Continuum filter + UV/IR cut. Wow! I could just about see to focus and after waiting I had one moment of really clear seeing to get this image.
ImageSun_083606_05_05_2018_ by Alexandra Hart, on Flickr
I am over the moon with it :hamster: then a hour later I managed another :hamster:
ImageSun_093149_05_05_2018_ by Alexandra Hart, on Flickr
Hopefully now I know the set up I should be faster tomorrow and maybe try a 3x Barlow. All this would not have been possible without the very kind donation of some Baader 3.8 film from Ewan Hobbs :bow2
Has thanked: 1357 times
Been thanked: 746 times
Re: First Light with Celestron C11
Post by ffellah »
Beautiful, very sharp granulation, Alexandra ! Congratulation on the solar debut of the large scope
Franco :bow :band
PDB
Been thanked: 63 times
Post by PDB »
That looks excellent!
Rgrds,
Paul
Has thanked: 38 times
Been thanked: 133 times
Post by Valery »
Wow! Very nice debut of your C11 !!!
Hope you always will be blessed with such a seeing.
Note, that it is more difficult to get such a good resolution and sharpness at green light than at deep red and H-a in particular.
yltansg
Has thanked: 909 times
Been thanked: 535 times
Post by yltansg »
Hi Alexandra,
Congrats!! You have caught gems on the Sun :)
Alfred
pedro
Has thanked: 4 times
Been thanked: 1406 times
Post by pedro »
Fantastic HR WL first images with your C11. Well done, nice resolution
GreatAttractor
Has thanked: 163 times
Been thanked: 94 times
Post by GreatAttractor »
Excellent results, Alexandra. I like the filter holder, what brand is it? (Or is it homemade?).
My software:
My images
stef41
Has thanked: 46 times
Been thanked: 449 times
Post by stef41 »
excellent!
the granulation stings the eyes! ;)
Has thanked: 25 times
Been thanked: 105 times
Post by Merlin66 »
Alexandra,
I also have and use the C11, the best investment I made was to have a clamp on the dovetail. Can’t remember the UK supplier of hand but it makes lifting and fitting the OTA much easier and safer.
Thanks everyone, I was absolutely over the moon to get such a good pic to start off with, I hope the weekend continues to bear fruit :)
Filip, I bought this filter from Rupert (Astrograph) http://astrograph.net/EMC-S100-Solar-Filter-Size-10 but sadly Baader don't sell the big rolls of ND3.8 anymore. Thankfully Ewan had some of his roll he gave me and I fitted it into the cell. You really need ND3.8 for imaging, the ND5 that came with it was next to useless as it was so dark.
rsfoto
Has thanked: 2653 times
Been thanked: 1981 times
Post by rsfoto »
Hi Alexandra,
WOW amazing fine detail on the rice grain
:band
robert
Has thanked: 2 times
Been thanked: 236 times
Post by robert »
Great result and handle 😁. Very impressive
Robert
2021 images https://tinyurl.com/d7jbz3sw
2020 images https://tinyurl.com/v6muwvm
christian viladrich
Been thanked: 380 times
Post by christian viladrich »
An excellent start with the C11. Very promising.
As Valery said, you should consider includind a red filter in your tool box
Has thanked: 1842 times
Been thanked: 1652 times
Post by Carbon60 »
Excellent, Alexandra. Very nice granulation images. I tried with my 250 RCT in H-a, but couldn't get anything because the sky was too hazy early on.
Derek Klepp
Been thanked: 171 times
Post by Derek Klepp »
All I can say is that look out when you image in Ha and CaK with that scope.What a truly delightful image and good to see Hubby back in action.
Cheers Derek
RodAstro
Has thanked: 154 times
Been thanked: 173 times
Post by RodAstro »
Hi Alexandra
Justa little tip, it is worth investing in another puck/clamp for the dovetail plate on the C11 and leaving it permanently on the C11 dovetail plate just in front of the ADM one you have on your mount.
Then when mounting the tube you can just put the dovetail plate into the ADM clamp and let it slide back to the new clamp, the new clamp will now rest against the ADM one on the mount and take the weight of the tube allowing you to use one hand to tighten the ADM clamp screws whilst steading the tube with your other hand.
And of course if the new clamp is in the correct place on the dovetail you tube will be in balance right away
I hope this makes sense
Cheers Rod
RodAstro
Post by RodAstro »
Oops forgot to say brilliant pictures
Rod
krakatoa1883
Has thanked: 117 times
Been thanked: 385 times
Post by krakatoa1883 »
Very well imaged granulation, Alexandra. I purchased a 3.8 filter for my Mewlon 210 with the same purpose in mind (there is not much to image than granulation...).
Raf
Thanks everyone for the suggestions, all noted :)
mattwastell
Been thanked: 40 times
Post by mattwastell »
Congratulations on these first up images - they are fantastic! Looking forward to your adventures!
Matt Wastell
Look up, look good!
http://www.pbase.com/mattwastell
Has thanked: 4476 times
Been thanked: 1977 times
Brilliant! I'm glad you got things up and running.
