First Light with Celestron C11
- Has thanked: 17648 times
- Been thanked: 8787 times
This morning a miracle happened, it was totally clear blue sky early in the morning. Finally I have handles on the C11 although I still needed the hubby's help as I didn't have a third hand to tighten the clasp screws but he managed that fine
Celestron C11 by Alexandra Hart, on Flickr
I didn't expect to see anything but I tried 2x Barlow and the Baader solar film ND3.8 and the Baader Continuum filter + UV/IR cut. Wow! I could just about see to focus and after waiting I had one moment of really clear seeing to get this image.
Sun_083606_05_05_2018_ by Alexandra Hart, on Flickr
I am over the moon with it then a hour later I managed another
Sun_093149_05_05_2018_ by Alexandra Hart, on Flickr
Hopefully now I know the set up I should be faster tomorrow and maybe try a 3x Barlow. All this would not have been possible without the very kind donation of some Baader 3.8 film from Ewan Hobbs
- Has thanked: 9143 times
- Been thanked: 6024 times
Re: First Light with Celestron C11
Beautiful, very sharp granulation, Alexandra ! Congratulation on the solar debut of the large scope
Wow! Very nice debut of your C11 !!!
Hope you always will be blessed with such a seeing.
Note, that it is more difficult to get such a good resolution and sharpness at green light than at deep red and H-a in particular.
- yltansg
- Has thanked: 1446 times
- Been thanked: 1423 times
- Been thanked: 6573 times
Fantastic HR WL first images with your C11. Well done, nice resolution
- GreatAttractor
- Has thanked: 747 times
- Been thanked: 753 times
Excellent results, Alexandra. I like the filter holder, what brand is it? (Or is it homemade?).
- stef41
- Has thanked: 120 times
- Been thanked: 1476 times
- Has thanked: 173 times
- Been thanked: 615 times
Alexandra,
I also have and use the C11, the best investment I made was to have a clamp on the dovetail. Can’t remember the UK supplier of hand but it makes lifting and fitting the OTA much easier and safer.
Thanks everyone, I was absolutely over the moon to get such a good pic to start off with, I hope the weekend continues to bear fruit
Filip, I bought this filter from Rupert (Astrograph) http://astrograph.net/EMC-S100-Solar-Filter-Size-10 but sadly Baader don't sell the big rolls of ND3.8 anymore. Thankfully Ewan had some of his roll he gave me and I fitted it into the cell. You really need ND3.8 for imaging, the ND5 that came with it was next to useless as it was so dark.
- Has thanked: 9401 times
- Been thanked: 5558 times
Hi Alexandra,
WOW amazing fine detail on the rice grain
- robert
- Has thanked: 4 times
- Been thanked: 1274 times
Great result and handle . Very impressive
Robert
Robert
- Been thanked: 2712 times
An excellent start with the C11. Very promising.
As Valery said, you should consider includind a red filter in your tool box
- Has thanked: 8415 times
- Been thanked: 8161 times
Excellent, Alexandra. Very nice granulation images. I tried with my 250 RCT in H-a, but couldn't get anything because the sky was too hazy early on.
- Been thanked: 171 times
All I can say is that look out when you image in Ha and CaK with that scope.What a truly delightful image and good to see Hubby back in action.
Cheers Derek
Cheers Derek
- Has thanked: 286 times
- Been thanked: 399 times
Hi Alexandra
Justa little tip, it is worth investing in another puck/clamp for the dovetail plate on the C11 and leaving it permanently on the C11 dovetail plate just in front of the ADM one you have on your mount.
Then when mounting the tube you can just put the dovetail plate into the ADM clamp and let it slide back to the new clamp, the new clamp will now rest against the ADM one on the mount and take the weight of the tube allowing you to use one hand to tighten the ADM clamp screws whilst steading the tube with your other hand.
And of course if the new clamp is in the correct place on the dovetail you tube will be in balance right away
I hope this makes sense
Cheers Rod
Cheers Rod
- krakatoa1883
- Has thanked: 153 times
Very well imaged granulation, Alexandra. I purchased a 3.8 filter for my Mewlon 210 with the same purpose in mind (there is not much to image than granulation...).
- mattwastell
- Has thanked: 2 times
- Been thanked: 72 times
Congratulations on these first up images - they are fantastic! Looking forward to your adventures!
- Has thanked: 20424 times
- Been thanked: 10242 times
Brilliant! I'm glad you got things up and running.
