The seeing was not very cooperative this morning. Finally, I managed to get a decent view of AR2706 with an ongoing small flare.
Some isolated very small bright points are visible here and there :
Tiny AR2706 in Ca K with the TOA150 on May 6
- Has thanked: 1 time
- Been thanked: 2713 times
Re: Tiny AR2706 in Ca K with the TOA150 on May 6
Hello Christian,
Just a perfect image for such an aperture!
Christian, tell us how much better this ASI290 camera for CaK imaging vs your older Basler 1920-155 with the IMX174chip ?
Your latest CaK images are so free from a noise and in particular from the read out noice! Is this camera a cooled one or not?
Hope we will see more such your CaK pictures.
- krakatoa1883
- Has thanked: 153 times
- Been thanked: 496 times
Really impressive, Christian.
- Has thanked: 17672 times
- Been thanked: 8791 times
Wow!! superb picture and the camera looks good too
Thanks a lot !
Valery, regarding the ASI290 here are some comments :
- I first compared the IMX174 and the IMX290 for imaging Venus in UV. I had the feeling that the IMX290 had a better quantum efficiency in UV. It was difficult to be sure of that since the gain (e-/ADU) and the full well in e- are very different.
- So I made some tests in Ca K on the Sun. And again, I had the feeling that the quantum efficiency of the IMX290 was a bit higher in UV.
BTW, Christian Buil measured a 67% QE at 400 nm :
According to the following source, the QE of the IMX174 at 400 nm seems to be arround 50% :
https://www.ptgrey.com/support/downloads/10414
So, this is consistent with a slightly higher QE of the IMX290 at 400 nm compared to the IMX174.
- Furthermore, the resulting image quality is quite good with 60 stacked images. So, I think I'll stick to the ASI290 for HR Ca K imaging.
Skyrunner, 30 fps is far from enough. I run at 170 frames/s. This makes a huge difference.
Regarding optics, I think a long focus 150 to 200 mm Newtonian could do the job (with an internal ERF in front of the secondary mirror).
I am finally thinking that a 200 mm telescope can make sense for HR Ca K imaging...
- Has thanked: 20435 times
- Been thanked: 10245 times
Excellent shot Christian!
- Has thanked: 9144 times
- Been thanked: 6025 times
