The Sun on May 5 2018 as seen with 280mm aperture.
This morning was a calm with good seeing. I caprtured the sun in CaK and H-a.
The image in CaK was taken first when the seeing didn't start to degrade with the sun going higher in the sky.
- AR12708 in CaK at 0,087"/pixel
- AR12708-April-05-2018-C11-06h-46m-UT-CaK.jpg (1.07 MiB) Viewed 2924 times
- AR12708 in H-a with a mini-flare
- AR12708-April-05-2018-C11-06h-52m-UT-H-a.jpg (493.74 KiB) Viewed 2924 times
- some activity at the eastern limb
- April-05-2018-C11-06h-55m-UT-H-a.jpg (494.61 KiB) Viewed 2924 times
- April-05-2018-C11-07h-01m-UT-H-a.jpg (378.86 KiB) Viewed 2924 times
- Has thanked: 9074 times
- Been thanked: 5977 times
Re: The Sun on May 5 2018 as seen with 280mm aperture.
Excellent resolution, Valery. AR2708 is so tiny....
- Has thanked: 17521 times
- Been thanked: 8763 times
Yes, Franco, the resolution here at 393nm is about as a 465mm telescope has at H-a 656nm.
A par with 300mm telescope at 430nm G-band.
As soon as my SCT has obtained a corrective optics for 393nm, the images at this wave length became much better and often have a diffraction limited resolution.
- Been thanked: 4880 times
Thanks to all you.
- pedro
- Has thanked: 14 times
- Been thanked: 6556 times
Great shots Valery, nice resolution
Pedro Re'
- Has thanked: 20229 times
- Been thanked: 10111 times
These are brilliant Valery!
Thank you, Pedro and Mark.
I hope to make more hig res solar photos in the CaK line.
Are you using the SAFIX with the CaK shots Valery?
This time I didn't use the SAFIX. Another corrective lens has been used.
Valery.
- Has thanked: 8352 times
- Been thanked: 8103 times
Fabulous, Valery. Wonderful images.
Thank you, Alex and Stu.
You can see it here: https://www.cloudynights.com/topic/6181 ... try8578847
Unfortunately the seeing was not good at all.
