The Sun on May 5 2018 as seen with 280mm aperture.
Has thanked: 156 times
Been thanked: 893 times
Post by Valery »
This morning was a calm with good seeing. I caprtured the sun in CaK and H-a.
The image in CaK was taken first when the seeing didn't start to degrade with the sun going higher in the sky.
AR12708 in CaK at 0,087"/pixel
AR12708 in H-a with a mini-flare
some activity at the eastern limb
Derek Klepp
Been thanked: 171 times
Re: The Sun on May 5 2018 as seen with 280mm aperture.
Post by Derek Klepp »
Excellent set Valery.
Has thanked: 9280 times
Been thanked: 6125 times
Post by ffellah »
Excellent resolution, Valery. AR2708 is so tiny....
Has thanked: 17888 times
Been thanked: 8887 times
Wow!! what a set!! :bow :bow :bow
Post by Valery »
ffellah wrote: Mon May 07, 2018 10:46 am Excellent resolution, Valery. AR2708 is so tiny....
Yes, Franco, the resolution here at 393nm is about as a 465mm telescope has at H-a 656nm.
A par with 300mm telescope at 430nm G-band.
As soon as my SCT has obtained a corrective optics for 393nm, the images at this wave length became much better and often have a diffraction limited resolution.
Been thanked: 4957 times
Post by eroel »
Valery:
Super shots.
Post by Valery »
Thanks to all you.
pedro
Has thanked: 14 times
Been thanked: 6683 times
Post by pedro »
Great shots Valery, nice resolution
Has thanked: 20732 times
Been thanked: 10427 times
These are brilliant Valery!
Post by Valery »
Thank you, Pedro and Mark.
I hope to make more hig res solar photos in the CaK line.
Are you using the SAFIX with the CaK shots Valery?
Post by Valery »
marktownley wrote: Mon May 14, 2018 1:38 pm Are you using the SAFIX with the CaK shots Valery?
This time I didn't use the SAFIX. Another corrective lens has been used.
Valery.
allhoest
Has thanked: 714 times
Been thanked: 496 times
Post by allhoest »
Once again, great shots!
CS
Alex
Has thanked: 8523 times
Been thanked: 8251 times
Post by Carbon60 »
Fabulous, Valery. Wonderful images.
Post by Valery »
Thank you, Alex and Stu.
allhoest
Post by allhoest »
Great shot in CaK.
I look forward for your next posts with the new corrective lens.
CS
Alex.
Post by Valery »
allhoest wrote: Sun May 27, 2018 9:14 am Great shot in CaK.
CS
Alex.
You can see it here: https://www.cloudynights.com/topic/6181 ... try8578847
Unfortunately the seeing was not good at all.
