My T250 newton is treated to partly reflect the blue spectrum.
I made some pics in Kline already.
Now is it time to try in CaK.
Here, with the Lunt CaK setup mounted on the scope:
T250 + barlow x2
Here, with the filter as a CaK mod:
T250 + barlow x2.5
Well, the x2.5 brings a strange optical effect.
CS
Alex
First trial - T250 + CaK
- Has thanked: 8355 times
- Been thanked: 8103 times
Re: First trial - T250 + CaK
The x2 looks great.
- Has thanked: 173 times
- Been thanked: 615 times
Alex,
Very nice.
What’s the native focal ratio?
Very nice.
Good start in the CaK, Alex!
The aperture does it's job nicely!
- Has thanked: 695 times
Hi!
Thanks for the comments.
The mirror is coated to reflect the red domain (for Ha) and the deep blue in less extend however. It was treated by MCM Optique in France.
The mirror was ground at f7, so F1750mm.
CS
Alex
CS
Alex
- Has thanked: 20240 times
- Been thanked: 10115 times
Good shot! That barlow introduces some strange aberrations.
Thank you Mark. I was using a Powermate x2.5.
Reading comments from others, the powermate has an evident field curvature when the distance to the ccd is too big.
Which was the case, because I was using the original diagonal between the powermate and the CCD.
Valery, thank you. But you are going in even higher resolution with your scope.
CS
Alex.
CS
Alex.
