First trial - T250 + CaK
allhoest
Has thanked: 714 times
Been thanked: 496 times
Post by allhoest »
My T250 newton is treated to partly reflect the blue spectrum.
I made some pics in Kline already.
Now is it time to try in CaK.
Here, with the Lunt CaK setup mounted on the scope:
T250 + barlow x2
Here, with the filter as a CaK mod:
T250 + barlow x2.5
Well, the x2.5 brings a strange optical effect.
CS
Alex
Has thanked: 8523 times
Been thanked: 8253 times
Re: First trial - T250 + CaK
Post by Carbon60 »
The x2 looks great.
Has thanked: 174 times
Been thanked: 618 times
Post by Merlin66 »
Alex,
Very nice.
What’s the native focal ratio?
Valtori
Has thanked: 312 times
Been thanked: 182 times
Post by Valtori »
Hi Alex,
Very nice CaK shots there!!
Val
Has thanked: 156 times
Been thanked: 893 times
Post by Valery »
Good start in the CaK, Alex!
The aperture does it's job nicely!
allhoest
Post by allhoest »
Hi!
Thanks for the comments.
The mirror is coated to reflect the red domain (for Ha) and the deep blue in less extend however. It was treated by MCM Optique in France.
The mirror was ground at f7, so F1750mm.
CS
Alex
Has thanked: 20738 times
Been thanked: 10437 times
Good shot! That barlow introduces some strange aberrations.
allhoest
Post by allhoest »
Thank you Mark. I was using a Powermate x2.5.
Reading comments from others, the powermate has an evident field curvature when the distance to the ccd is too big.
Which was the case, because I was using the original diagonal between the powermate and the CCD.
Valery, thank you. But you are going in even higher resolution with your scope.
CS
Alex.
