First worthwhile results from a high res set up
- Been thanked: 1735 times
This is the latest start to solar imaging in my memory due to lack of solar features and poor seeing.
The sky had variable patches of haze with some areas of interest on the sun.
It was a good day to test an f/30 system using a just acquired TZ3 Baader telecentric carrying a Quark Combo chromosphere on the back end of a c9.25 with an Aries 265 mm ERF up front.
The threads on this telecentric allow it to be attached to the accessory threads on the back of the c9.25. However, the c9.25 accessory threads are too long to fit completely into the body of the telecentric. Nonetheless, it is a secure connection. I would prefer a T2/2" nosepiece attachment on the telecentric to allow it to slip in to the 2" visual back that I usually have on the back of c9.25.
The efl was 6900 mm, somewhat higher than the conditions could support but the image contrast was higher than I remember when I first used a Powermate 2.5X on the same scope last year.
Lou
PS
I went rummaging through some extension tubes for their nosepieces and eyepiece holders and found a nose piece and T2 eyepiece holder that fit the TZ3, all for a more secure setup.
c9.25 at 6900mm
LS152 at 3800 mm
LS80 at 1120mm (forgot about rotating the ghost out)
Lou
PS
c9.25 at 6900mm
LS152 at 3800 mm
- Has thanked: 9243 times
- Been thanked: 5500 times
Re: First worthwhile results from a high res set up
Great images. Nice resolution in the prominences.
- Has thanked: 9074 times
- Been thanked: 5977 times
Nice first results, Lou. I know how you feel about horrible weather conditions.
Hi Lou,
Good results for the start.
BTW I would suggest to use a focal reducer (with different spaces) to make image scale smaller. Different F/D for different seeing conditions and objects. This also give you shorter exposures and faster fpl =better fight against the seeing, more stacked images, higher S/N = better resolution, nicer images.
The scale you do use now is noticeably larger than I do use with larger C11 telescope.
- Has thanked: 20229 times
- Been thanked: 10111 times
That first closeup came out very well Lou!
- Has thanked: 17521 times
- Been thanked: 8763 times
Wow!!!! what beautiful detail in the proms nice to see you getting some super results
- Been thanked: 171 times
Thanks Lou I think my Solar scopes have gone into hibernation in their cupboard.
- Has thanked: 8352 times
- Been thanked: 8103 times
Nice images, Lou.
- Has thanked: 55 times
- Been thanked: 81 times
Great 'first worthwhile light' Stu!
Impressive that you get images at that focal ratio. In continuum imaging with my 11 inch I usually work at f/D=22 with my IMX174 camera. If you wanted to try that the Baader 0.7 refucer behind the etalon would get you there...
Good luck for your next solar session - and happy seeing...
Best, Laura
Best, Laura
- Been thanked: 6556 times
Insteressing first HR shots Lou, please keep us posted
In addition to Laura's recommendation concerning the image scale, I can add that imaging of the promonencesLauraMS wrote: ↑Fri May 25, 2018 3:54 pm Great 'first worthwhile light' Stu!
Best, Laura
require even smaller scale - to make the image brighter, sharper and to get the exposures as short as possible.
Thanks Laura and Valery for the useful advice. A 0.7X reducer would be ideal since originally I looked at this c9.25 to be used at about 4600mm (with a 2X Powermate), a short jump from my LS152 at 3800mm. I didn't know there were any at that reduction factor but I will look at the Baader.
Lou
Lou
I do use a 0,5x GSO simplest reducer with shortened space between it and the camera chip. The shorter the space, the less the reduction. In fact I got three different barrels and this give me the possibility to vary the image scale in a wide enough range.gabrieli wrote: ↑Sat May 26, 2018 2:07 pm Thanks Laura and Valery for the useful advice. A 0.7X reducer would be ideal since originally I looked at this c9.25 to be used at about 4600mm (with a 2X Powermate), a short jump from my LS152 at 3800mm. I didn't know there were any at that reduction factor but I will look at the Baader.
Lou
