Sol from the 20th of May 2018.
Been thanked: 4959 times
Post by eroel »
Hi:
Had not been able to process images taken several days ago, but did a quick processing of the ones taken the 20th, with the Solarmax 90-DS, with the Meade 102mm f/9 with a CaK mod and with the 102mm f/7 Stellarvue with a 4X Telecentric and an old Daystar T-Scanner filter. Used also the SKYnyx 2-2 and the ASI174 cameras.
Thanks for looking a lot of shots.
Weather has been hazy, clouded and rained almost everyday. :mad:
Sol del 20 de mayo de 2018-Meade-CaK-PSTmod-1an.jpg (861.45 KiB) Viewed 798 times
Sol del 20 de mayo de 2018-Meade-CaK-PSTmod-1inv.jpg (955.29 KiB) Viewed 798 times
Sol del 20 de mayo de 2018-Meade-CaK-PSTmod-2an.jpg (845.87 KiB) Viewed 798 times
Sol del 20 de mayo de 2018-Meade-CaK-PSTmod-2inv.jpg (949.75 KiB) Viewed 798 times
Sol del 20 de mayo de 2018-Solarmax 90-DS-BF30-1an.jpg (1007.14 KiB) Viewed 798 times
Sol del 20 de mayo de 2018-Solarmax 90-DS-BF30-1inv.jpg (1.05 MiB) Viewed 798 times
Sol del 20 de mayo de 2018-Solarmax 90-DS-BF30-2an.jpg (1015.42 KiB) Viewed 798 times
Sol del 20 de mayo de 2018-Solarmax 90-DS-BF30-2inv.jpg (1.06 MiB) Viewed 798 times
Sol del 20 de mayo de 2018-Stellarvue-Daystar-1an.jpg (960.53 KiB) Viewed 798 times
Sol del 20 de mayo de 2018-Stellarvue-Daystar-1inv.jpg (1.03 MiB) Viewed 798 times
Sol del 20 de mayo de 2018-Stellarvue-Daystar-2an.jpg (803.77 KiB) Viewed 798 times
Sol del 20 de mayo de 2018-Stellarvue-Daystar-2inv.jpg (802.69 KiB) Viewed 798 times
Sol del 20 de mayo de 2018-Stellarvue-Daystar-3an.jpg (1.17 MiB) Viewed 798 times
Sol del 20 de mayo de 2018-Stellarvue-Daystar-3inv.jpg (1.15 MiB) Viewed 798 times
Sol del 20 de mayo 2018-STellarvue-Daystar-1an.jpg (1.04 MiB) Viewed 798 times
Sol del 20 de mayo 2018-STellarvue-Daystar-1inv.jpg (1.2 MiB) Viewed 797 times
Has thanked: 20757 times
Been thanked: 10442 times
Re: Sol from the 20th of May 2018.
A great set of shots there Eric! I enjoyed them :)
Has thanked: 9298 times
Been thanked: 6133 times
Post by ffellah »
Still you had very good results, Eric.
Has thanked: 8523 times
Been thanked: 8259 times
A very fine set of images, Eric. You've been busy.
Post by eroel »
Thanks Mark, Franco and Stu.
