Help! Tiltadaptor and Lunt LS50..
Taipan
Post by Taipan » Fri May 25, 2018 1:57 pm
Anyone used any tiltadaptor with the LS50 and achieved focus?
Trying to get rid of NR....
Lunt LS50THa/B600PT SS. ZWO ASI 120MM-S. Skywatcher Esprit 80ED with homemade Baader solarfilm filter and solarcontinuum filter.
krakatoa1883
Re: Help! Tiltadaptor and Lunt LS50..
Post by krakatoa1883 » Fri May 25, 2018 6:41 pm
The problem is to reach focus with the tilt adapter inserted between diagonal and camera. Baader Planetarium sells an ultra short C-T2 adapter, I use it to focus my Chameleon and taking full discs with my Lunt50, I'll try it with the tilt adapter in place and I'll let you know.
T2 (1).jpg (49.04 KiB) Viewed 755 times
My personal page on Google+
FlankerOneTwo
Post by FlankerOneTwo » Sat May 26, 2018 7:06 am
Unfortunately the lack of back focus is one of the limiting factors in using the LS50 for imaging, and was a big part of me moving to the LS80. I could get it to focus with the 50 by removing the B600 nosepiece and screwing the blocking filter directly to the back of the focuser with a T adapter ring, and using a QHY174 which you can poke all the way down through the eyepiece holder and tilter to get the sensor right on top of the blocking filter aperture. You might not be able to get the ASI120 close enough.
krakatoa1883
Post by krakatoa1883 » Sat May 26, 2018 2:51 pm
OK, my LS50 reaches focus with the tilt adapter, provided the short C-T2 connection is used.
Taipan
Post by Taipan » Mon May 28, 2018 7:06 am
What tiltadaptor are you using?
krakatoa1883
Post by krakatoa1883 » Mon May 28, 2018 7:49 am
This one from TS
Taipan
Post by Taipan » Mon May 28, 2018 3:56 pm
Ok. Tnx. Maybe try this adaptor. I don't hav to tilt tha camera so much så it might work as long as a reach focus.
Taipan
Post by Taipan » Tue May 29, 2018 3:21 pm
Hmm, i now se that you don't have the helical focuser? It your shorter than the original?
krakatoa1883
Post by krakatoa1883 » Tue May 29, 2018 6:20 pm
I installed the FT crayford focuser and I no longer have the original one, so I can't compare them. Sorry.
Taipan
Post by Taipan » Sat Jun 02, 2018 2:01 pm
Just for info.. It didn't work for me. Can't reach fokus with that adaptor and T2ti-ti ring. Guess i just have to live with the nr or take them away in PS. But thanx for help and tips.
FlankerOneTwo
Post by FlankerOneTwo » Sun Jun 03, 2018 4:50 am
I did not notice any change in the available back focus when I changed from the stock helical focuser to the Feathertouch on the LS50. I went down this road too.
Taipan
Post by Taipan » Sun Jun 03, 2018 9:17 am
Ok. Tnx. Then i just have to utse PS to remove them. Not the best solution bit it works..
Users browsing this forum: No registered users and 4 guests
