Hey all,
Well, the clouds were thick and lots of rain today, but I got lucky with some sucker holes with some bad seeing around 2pm or so. Took the bait and I went to imaging. I recently added some saddles to my imaging platform for solar so that I could move between several scopes for different purposes quickly. It puts a ton of instruments on my mount, and it weighs a lot, but properly balanced it manages fine, and I'm still able to image reliably with the seeing being my limiter. This way once I get everything together, I can quickly image in several wavelengths and different scales. Today I bounced between HA (656.28nm), CA (393nm) & WL (540nm). I didn't get much time, so I didn't get to complete my sequences, but I got some data regardless. No real noteworth proms that I could find today, at least when I was browsing the limbs around 2pm Eastern time. So I focused on the spots and attempted a mosaic of the full disc.
For the mosaic discs in HA, please take a moment to look at the full resolution images on Flickr or my Astrobin, they're significantly different than these thumbnails, thanks!
Equipment:
Orion Sirius (HEQ5) Mount
Farpoint Side by Side Vixen Saddles (to allow dual mounts)
Celestron 120mm F8.3 with Orion ST8 piggy back mounted (with 60mm aperture mask)
Orion 80mm ED F7.5 APO with 50mm F3.8 finder scope piggy back mounted (with solar filter)
Quark Chromosphere for the HA
Skybender + dual stack of 393nm filters for CA
Baader Solar Film + Baader Solar Continuum filter for WL
The Triple-Threat!
Results (Colored Data):
Hydrogen Alpha
Mosaic made with ST80 (60mm aperture mask, F6.6) with Quark; please take a moment to look at the flickr or astrobin link at full resolution, it's significantly different from these thumbnails!
Calcium
White Light for comparison
Sunspots AR2712 & AR2711, Full Discs, HA & CA | May 25th 2018
- Has thanked: 1188 times
- Been thanked: 1382 times
- PDB
- Has thanked: 2 times
- Been thanked: 149 times
Re: Sunspots AR2712 & AR2711, Full Discs, HA & CA | May 25th 2018
Hi Marty,
you'r right. The full size ones look a lot better. Seems to be some pattern in the images which is not visible at full resolution but gets intensified with resizing the image. What camera did you use? I see such problems very often with my ASI178, but then it is a sort of crosshatch pattern.
Impressive setup. Surprised that you can drive that load on an HEQ5 type mount.
Rgrds,
Rgrds,
Hey Paul,
ASI174MM for everything. The pattern is probably subtle newton rings that my flats didn't totally correct for, and then when stitched they were crossing each other, etc. When scaled down, it shows up more, at full resolution it doesn't seem to show up at least as obvious.
- p1taylor
- Has thanked: 1 time
- Been thanked: 219 times
Super images.
peter
peter
LUNT LS 60THa WITH PRESSURE TUNER, BLOCKING FILTER B1200, Skywatcher Startravel 80T OTA, ZWO ASI 178MM, lot of bit
- Has thanked: 20779 times
- Been thanked: 10462 times
Very nice set of images Marty!
- Been thanked: 4971 times
Marty:
Beautiful session and set of images.
- Has thanked: 17970 times
- Been thanked: 8904 times
Wow! these certainly are a treat on Flickr
