AR12709 remnants close up in the Ca II K line.
Hi all
Early morning of May 15 was a clear with a slow breeze. The seeing was variable from so so to good.
I deceided to image the sun in CaK first.
Equipment used: C11 280mm F/10 SCT on the EQ8 mount, ARIES full size 295mm two bands DERF,
PST CaK filter, Basler 1920-155 camera.
The Sun was blank and only a tiny remnants of the AR12709 group were seen. It looks best in the CaK line.
In the H-a it was hidden by the chromosphere and in a white light it looks like a tiny pore barely detectable
on the desert background.
Such a large scale 0,13"/pix is necessary for correct sampling at such a wave length.
Thanks for looking and comments.
- AR12709-May-15-2018-UT-06h-01m-C11-280mm-PST-CaK-0,13sec-pix.jpg (485.5 KiB) Viewed 3031 times
- Been thanked: 4340 times
Re: AR12709 remnants close up in the Ca II K line.
Excellent resolution Valery
You have the capture/processing techniques well adapted to this type of hi-res work.
MapleRidge wrote: ↑Sun May 27, 2018 9:43 pm Excellent resolution Valery
Brian, nothing special in capture&processing, really. If one has a proper equipment and is able to catch
seconds of good seeing, this all. The post processing is quite simple.
- Has thanked: 8415 times
- Been thanked: 8161 times
AWESOME.... excellent image, Valery.
- p1taylor
- Been thanked: 219 times
A really good shot.
peter
peter
- Has thanked: 20424 times
- Been thanked: 10243 times
Very impressive as always Valery!
- Has thanked: 17667 times
- Been thanked: 8787 times
These CaK images you take are really special Valery
Ledies and gentlemen,
Just read your so positive commets. Thank you all.
best,
best,
- Been thanked: 4904 times
Thank you, Eric!
BTW. When do you plan to start imaging with your 10" TEC Mak and 10" ARIES DERF?
- GreatAttractor
- Has thanked: 747 times
- Been thanked: 753 times
That's a great "diamond dust", Valery!
TheSkyBurner, that's an interesting comparison indeed.
Khe Khe... diamond dust? Thanks for such an unusual allegory.
