Hello,
Here are the results of my observing session of May 28 2018.
Unfortnately, the seeing was mediocre at best, especially in the CaK.
Images were obtained in CaK, then in 655nm continuum (unheated etalon) and then in H-a core.
Very different appearance of the Sun. It is a shame that the best seeing was when I imaged it with unheated etalon!
Once the etalon has reached it's temperature, the seeing told me bye bye and soon I quit the session.
Telescope used: C11 280mm F/10 SCT equipped with the ARIES 295mm DERF.
Thanks for looking and comments.
CS
The Sun in three different WL C11 scope.
- CaK
- AR12712-May-28-2018-UT-06h-36m.jpg (498.39 KiB) Viewed 1680 times
- Quark unheated at about 655nm
- AR12712-May-28-2018-UT-07h-29m.jpg (498.5 KiB) Viewed 1680 times
- H-a core
- AR12712-May-28-2018-UT-07h-47m.jpg (485.35 KiB) Viewed 1680 times
- Been thanked: 4904 times
- Has thanked: 9144 times
- Been thanked: 6025 times
- Has thanked: 17666 times
- Been thanked: 8787 times
Re: The Sun in three different WL C11 scope.
These are a great comparison Valery I tried an unheated Quark once and couldn't see anything but a blurred blank disc, you are lucky to see some contrast and find the granulation. I struggled to get any contrast even on band.
- Has thanked: 8415 times
- Been thanked: 8161 times
Very nice images, Valery. Superb detail.
- Been thanked: 171 times
Thanks to all for your kind words.
- Has thanked: 20424 times
- Been thanked: 10243 times
Great shots as always Valery!
- Been thanked: 4340 times
Excellent image Valery
