Today's SUN (20180601) + NEW scope
- pedro
- Has thanked: 14 times
- Been thanked: 6691 times
WEBLINK:
http://re.apaaweb.com/sun_h_alpha_2018-06.html
Good seeing today. AR12712 is still going strong.
I finally bought a TEC140. I still have to try it on the sun.
SOLAR IMAGING SESSION
TV 101, VIXEN FL70S, LUNT 60
GS3-U3-28S4M-C, GS3-U3-28S5M-C
Pedro Ré (20180601)
IMAGING SETUPS
IMAGING SETUPS
IMAGING SETUPS (TEC140)
IMAGING SETUPS (VIXEN FL70s + SM60)
IMAGING SETUPS (TV101 + SM60)
SUN (20180601) H-alpha DISK & PROMS (08:30 UTC). VIXEN FL70S, SM60, BF30, PGR GRASSHOPPER 3 GS3-U3-28S5M
SUN (20180601) H-alpha DISK & PROMS (08:30 UTC). LUNT60, BF30, PGR GRASSHOPPER 3 GS3-U3-28S4M
SUN (20180601) H-alpha DISK & PROMS (08:00 UTC). TV101 F/5.4, SM60, BF30, PGR GRASSHOPPER 3 GS3-U3-28S4M
SUN (20180601) CaK PROMS (08:00 UTC). TV101 F/5.4, LUNT 1200 CaK Module, PGR GRASSHOPPER 3 GS3-U3-28S4M
SUN (20180601) WL, CaK & H-alpha (08:00 UTC). TV101 F/5.4, LUNT 1200 CaK Module, SM60, BF30, PGR GRASSHOPPER 3 GS3-U3-28S4M
WEBLINK:
Pedro Ré (20180601)
IMAGING SETUPS
IMAGING SETUPS
- solar_imaging_session_20180601-072.jpg (1.93 MiB) Viewed 3093 times
- solar_imaging_session_20180601-078.jpg (906.42 KiB) Viewed 3096 times
- solar_imaging_session_20180601-083.jpg (989.46 KiB) Viewed 3096 times
- solar_imaging_session_20180601-090.jpg (816.55 KiB) Viewed 3096 times
Pedro Re'
- Been thanked: 4980 times
Re: Today's SUN (20180601) + NEW scope
Pedro:
All beautiful gear, bet you will love the TEC.
Abrazo,
Abrazo,
Welcome to the TEC club
Your friend seems to be make quick work of the greenery! she is cute
Oh and the Sun is nice too
- Has thanked: 9319 times
- Been thanked: 6156 times
Sweet! I have a TEC 140 on order as we speak. I'll be very eager to see your results.
- pedro
Thanks a a guys
I will love the TEC140 for sure
A quick question to Alexandra. The FT focuser has a black plastic piece near the focus. Is this going to be a problem when imaging the sun?
Pedro Re'
The active region came out really well, particularly sharp in CaK.
- pedro
- p1taylor
- Been thanked: 219 times
That is a good set of images of sun
peter
peter
- pedro
- Has thanked: 8558 times
- Been thanked: 8290 times
It's always a pleasure to see your setup and solar images....... and the organic lawnmower.
- Has thanked: 57 times
- Been thanked: 1204 times
- pedro
Thanks again guys
Stu: The organic lawnmower has eaten almost everything...
Pedro Re'
- Has thanked: 20813 times
- Been thanked: 10484 times
Good images Pedro and an excellent scope to add to your collection!
- pedro
Thanks Mark
The TEC140 is a great scope. My plans it to use it to image the Sun & Moon
Pedro Re'
Pedro, it depends on how old your TEC140 is. From my model upwards the end has a metal collet ring so there is no problem using a solar wedge. Pre that date folks used to remove the plastic one and replace with a metal one if they were to solar image. The plastic is OK as long as you don't let the sun sit at an angle through the wedge to burn the plastic. I have never had a problem with my version imaging for hours, but then you should never leave it unattended anyway and when imaging you are dead centre, so it shouldn't be a problem.
- pedro
Thanks Alexandra for your reply
I have the metal ring for the feathertouch focuser but it has to be machined to fit.
Pedro Re'
