Ha Filaprom June 11th
Has thanked: 185 times
Been thanked: 182 times
Post by Carbon60 » Mon Jun 11, 2018 6:52 pm
Just time for a 'quick' solar image this evening after work. I say 'quick' because by the time I've lugged all of my gear around the house to my back garden it feels like much longer than the few minutes that it actually takes, going back and forth, taking a few pieces at a time. Anyhow, moments after getting set up on target and everything aligned and tuned the seeing conditions went to pot; almost literally it was like looking at the bottom of a swimming pool after only a few moments of relative calm. Thankfully I'd just managed to capture this image of a nice filaprom before the scope became useless under the conditions.
150mm/DS Lunt 35 with a 2.5x Powermate and acA1920-155um camera. I'm sure I should have re-orientated the image, but hey.
4000 images stacked using AS!3 and deconvoluted using Imppg. Further processing in PixInsight.
Image20180611_Filaprom by Stuart Green, on Flickr
and an inverted version....
Image20180611_Filaprom_Inverted by Stuart Green, on Flickr
The limb gives away the fact that the tuning was a little bit off.
Thanks for looking.
Lunt LS60THa B1200 PTFT
DMK41, Basler acA1920-155
NEQ6 Pro-mount
Has thanked: 39 times
Been thanked: 26 times
Re: Ha Filaprom June 11th
Post by ffellah » Mon Jun 11, 2018 8:11 pm
That is a lovely prominence, Stu. I prefer the inverted version but they are both very nice. Lucky you had time to image on a work day.....
Has thanked: 613 times
Been thanked: 206 times
Post by Montana » Tue Jun 12, 2018 6:45 am
:) sounds like the Sun just started passing over the neighbours barbecue :lol:
Fantastic image, you can see how the plasma is like a thin veil and see through, what a delicate structure although it is probably the size of Earth.
:bow :hamster:
Derek Klepp
Been thanked: 23 times
Post by Derek Klepp » Tue Jun 12, 2018 8:27 am
Looks good orientated this way Stu.
gabrieli
Been thanked: 41 times
Post by gabrieli » Tue Jun 12, 2018 10:11 am
Hi, Stu
I always prefer a "right side up" orientation to prom images, just the way I look at life. The floating impression is enhanced this way.
Lou
Post by Carbon60 » Tue Jun 12, 2018 11:24 am
Many thanks for your feedback, everyone.
Certainly seemed that way, Alexandra..... :)
NEQ6 Pro-mount
eroel
Been thanked: 157 times
Post by eroel » Tue Jun 12, 2018 3:20 pm
Stu:
Beautiful Filaprom image in both versions.
I also prefer the "right side up" orientation in prominence images.
Has thanked: 772 times
Been thanked: 293 times
Post by marktownley » Wed Jun 13, 2018 5:35 am
That's a lovely shot Stu!
Post by Carbon60 » Wed Jun 13, 2018 6:40 pm
Many thanks, Eric & Mark.
NEQ6 Pro-mount
