Current ARs from June 16 afternoon
gabrieli
Been thanked: 1735 times
Post by gabrieli »
These were taken using an Aries 265mm ERF + C9.25 + 3X Baader Telecentric + Quark Combo +FLIR (5Mp) Blackfly during mid afternoon (1 - 2 pm local)
Yes, the scale is a bit much and the images a bit noisy (due to stacking only 200/1000 frames) but I haven't found a suitable reducer yet to bring it down to about 4500 - 5000mm without adding too much overhang. The Quark was showing very good contrast but the seeing caused very jittery fine detail.
The camera feels more and more comfortable now and I found that by reducing the ROI to 3Mp (as for the images below), the frame rate could be nudged up to about 98 fr/s if the image brightness allows it.
eroel
Been thanked: 4980 times
Re: Current ARs from June 16 afternoon
Post by eroel »
Lou:
Very promising setup.
Has thanked: 20819 times
Been thanked: 10489 times
Very good indeed!
Has thanked: 17974 times
Been thanked: 8906 times
Very impressive!! :bow
I don't understand why it would be so noisy though after stacking 200 frames, I only ever stack 50 and they seem OK?
Has thanked: 8559 times
Been thanked: 8290 times
Post by Carbon60 »
Hope you don't mind, but I've cleaned up some of the noise.....
Not ideal as I worked from your JPG file, but it shows promise.
gabrieli
Post by gabrieli »
As Stu implied, the noise came from excessive processing (over use of wavelets). The scale displayed should have been reduced a bit,
Lou
