Return of the Double Stack - 21st June
- Has thanked: 20442 times
- Been thanked: 10247 times
Hi All,
Long time no sun, busy at work and when have had free time been busy with other things... Anyways, if you remember my frustrations with inconsistencies I was having with my Lunt50 scope viewtopic.php?f=4&t=24369 well, I decided to go with Valerys suggestion of double stacked front mounted etalons, as, I already had one 50mm etalon (from the Lunt50) so decided to buy another with a view to double stacking them. Throw in a wait for various adaptors to be made and being busy at work and this morning allowed me to have first light. I mounted these on my 60mm f6 scope and used a BF15 as in the pic below.
image by Mark Townley, on Flickr
A smile came to me when I looked through the eyepiece for my first light, a lovely contrasty view!
Ha-Full-Disk-bw by Mark Townley, on Flickr
Ha-Full-Disk-colour by Mark Townley, on Flickr
For a first light i'm very pleased - the two etalons are not clocked yet, and the ERF on the inner etalon has not been removed yet, so, I know from experience there is still plenty of potential to improve the image further, I also have too much tilt on the camera (left of the disk is soft). What I like about this setup is that I can be imaging within minutes of being outside, which, for observing before work or in cloud gaps is important. Weather is supposed to be better for a week or so now, and work is quieter, so i'm hoping to do further tests. PGR chameleon 3 was used.
I hope i'm on a winner with this setup.
- Has thanked: 9145 times
- Been thanked: 6025 times
- Been thanked: 8792 times
Re: Return of the Double Stack - 21st June
Wow!! great images Mark I don't think you can beat a traditional etalon set up for great views down the eyepiece
- krakatoa1883
- Has thanked: 153 times
Very good contrst, the setup is really promising. Is that one your 60 mm apo ?
Thanks everyone. Yup, it's the 60mm Tecnosky apo i'm using here Raf.
- Has thanked: 173 times
- Been thanked: 615 times
Mark,
Looking promising!
As you know I used the SM60 double stacked external etalons on the ED80 for a while.....when they are "tuned" majic happens.
I'm sure you'll be successful.
Looking promising!
- Been thanked: 6577 times
It is surely a winner Mark. My experience with double stack front etalons is not great. I always have non uniform disks (lots of soft spots). Maybe I should try again
- Has thanked: 8418 times
- Been thanked: 8163 times
Looking good there, Mark.
My 150mm and 250mm /Lunt 35 scopes utilise a Coronado BF 15. Works well.
Thanks everyone. I got a second adaptor that allows me to use the etalon setup on other scopes; here it is on my Skywatcher ED80, it also fits on the Tal100R too as there is only a few mm difference in the tube sizes.
- Been thanked: 1735 times
Hi, Mark
I would be very happy if my full discs were that uniform, even after processing in PS.
I noticed that, in your first image, you have a Daystar Interference Eliminator. That's also my preferred method for handling Newton's rings.
I like how quick it is to find the minimal tilt you need and see the effect so quickly without fumbling with 3 pair of push/pull screws.
I do have a 2˚ wedge prism from Thorlabs in a c snout but, curiously, this snout, which was recommended by someone at Thorlabs, is not a 1.25" snout.
It's a bit less than that and isn't as secure as it should be. So, the wedge had to be secured in a proper sized snout.
When used with my Blackfly S, this wedge still leaves a small circular patch of Newton's rings on the right side of the image which I can't explain.
Lou
Lou
Thanks Lou, the interference eliminator is also my preferred method to get rid of newtons rings for exactly the reasons you state. This setup visually gives the most contrasty, if dimmer view.
It will work well on days of excellent transparency to get nice big full disk mosaics.
- Been thanked: 4904 times
Mark:
The FD´s are very uniform and contrasty.
Have a nice and sunny weekend,
