Got the tilt on the camera sorted this morning with todays full disk - happily with this setup it needs very little which means todays disk is sharper from limb to limb. Hoping to laser cut some gaskets in a bit and then hopefully should be able to finalise the clocking of etalons for a more even illumination across the disk.
Ha-Full-Disk-bw by Mark Townley, on Flickr
Ha-Full-Disk-colour by Mark Townley, on Flickr
Taken with a pair external Lunt 50mm etalons, Tecnosky 60mm f6 apo, BF15 and PGR Ch3.
Fridays Full Disk 22nd June
- Has thanked: 20813 times
- Been thanked: 10484 times
- marios i.
- Has thanked: 1707 times
- Been thanked: 1125 times
Re: Fridays Full Disk 22nd June
Wonderful images Mark.
Marios
Marios
Marios S.Ioannou
Sketcher/Visual Observer
Thanks Marios
- Has thanked: 9319 times
- Been thanked: 6156 times
Very nice disc Mark
I live in hope that it may be sunny this weekend
- krakatoa1883
- Has thanked: 153 times
- Been thanked: 496 times
A uniform disk, Mark, with much contrast. The large spotless active area to the east is also well defined.
Raf
- Has thanked: 1188 times
- Been thanked: 1382 times
Lovely disc!
Was this using FireCapture's version of flat calibration?
- Has thanked: 8558 times
- Been thanked: 8290 times
Very nice FDs, Mark. Looking good.
Cheers folks! These full disks are taken around f9, I use a barlow on a very short nosepiece to give me a magnification factor of ~1.25x, this allows me to maximise nearly full frame on the PGR Ch3. I also tried the etalon setup on the Tal100R as I had another adaptor plate made up. Here the images are running about f25 and the 3.45um pixels of the CH3 are just too small and at this scale a imx174 chipped camera with larger 5.86um pixels would be much better.
ar12713-ha-bw by Mark Townley, on Flickr
ar12713-ha-colour by Mark Townley, on Flickr
ar12715-ha-bw by Mark Townley, on Flickr
ar12715-ha-colour by Mark Townley, on Flickr
I think next time with the Tal I will not use the 1.25x barlow.
Just waiting for the haze to break this morning and hopefully get some good views later on.
