Double Stacked Active Regions on Saturday 23rd June
- Has thanked: 20767 times
- Been thanked: 10453 times
Very poor transparency today with lots of haze and high cloud, but continuing with different setups and I think this one gives the tightest bandpass and most contrasty view at the slight expense of image brightness. Visually the contrast is one of the best i've seen.
image by Mark Townley, on Flickr
ar12713-ha-bw by Mark Townley, on Flickr
ar12713-ha-colour by Mark Townley, on Flickr
ar12715-ha-bw by Mark Townley, on Flickr
ar12715-ha-colour by Mark Townley, on Flickr
My Lunt LS50C etalon is very good and requires no tilt to be on band. I could be silly and try triple stacking with my other 50mm etalon
Re: Double Stacked Active Regions on Saturday 23rd June
Very nice debute of new equipment, Mark!
To tell exactly is this really so, you need to check up this with a lazer collimator.
Adjust the etalon at the highest contrast of the details in the ceter of the FOV.
Put the lazer collimator in the focuser, rack out the focuser tube maximally.
Switch IN the lazer. See where is the reflected beam. If it very very near
the lazer beam output hole, then this etalon does not really need a tilt.
Hope this helps.
Hope this helps.
- Been thanked: 4971 times
Mark:
A very compact solar scope, and as for the images it looks like the setup will give very nice contrasty images.
Thanks Valery, thanks Eric.
- pedro
- Has thanked: 14 times
- Been thanked: 6688 times
Great images there Mark. It works like a charm
Pedro Re'
- Has thanked: 17970 times
- Been thanked: 8902 times
Very nice pictures, looking forward to a summer of contrasty images from you Mark
- Has thanked: 8543 times
- Been thanked: 8271 times
Looking good there, Mark. It will be interesting to see further results from this setup over the summer.
- Been thanked: 171 times
Go on be silly.Once again great results Mark.
- marios i.
- Has thanked: 1707 times
- Been thanked: 1125 times
Beautiful images Mark!
Marios
Marios
Marios S.Ioannou
Sketcher/Visual Observer
- krakatoa1883
- Has thanked: 153 times
- Been thanked: 496 times
Very good images, I like much your processing.
Raf
Thanks everyone! Waiting to get my mount back up and running again now before imaging can resume.
