Full discs with LS50 and TS80ED
- krakatoa1883
- Has thanked: 153 times
- Been thanked: 496 times
Solar activity is returning to be very low as AR12715 is approaching the W limb. There are few prominences on the limb (yesterday there was a fine one on the W) and a filament is visible on the disc inside a large area of magnetic activity but without details in WL. This morning I counted 7 spots in AR12715 .
I have finally been able to obtain a fairly uniform disc with my pressure tuned LS50, it was quite simple but I didn't realize it immediately: it has been sufficient to rotate the diagonal to a 9 o'clock position There should be some kind of mismatch between the BF and some other component(s) inside the tube, rotating the diagonal compensates most of the unevennes.
- 20180625_prom.jpg (60.62 KiB) Viewed 2117 times
- 2018-06-26-0943-RB-Halpha-fulldisc.jpg (412.09 KiB) Viewed 2117 times
- 2018-06-26-0847-RB-CaH-fulldisc.jpg (342.45 KiB) Viewed 2117 times
- 2018-06-25-0843-RB-Halpha-fulldisc.jpg (402.36 KiB) Viewed 2117 times
Raf
- Been thanked: 5 times
Re: Full discs with LS50 and TS80ED
Do you use a tilt adapter or do Newton rings not pose a problem for you, I cannot get a uniform disc in a single shot I have to do mosaics.I will have to try rotating the diagonal.
Brendan
Lunt LS50THa with B600 b/f, W/O 72 Megrez, Lunt Herschel wedge, 6" F8 Herschel Newtonian, PGR Grasshopper 3, Opticstar pl131c,
- Been thanked: 4980 times
- krakatoa1883
Thanks Eric.
Brendan, I do not have Newton rings with my Lunt and the Chameleon mono, I have them with the Quark, in this case I use a TS tilt adapter but only when making a flat is not enough to get rid of them.
Raf
- Has thanked: 9319 times
- Been thanked: 6157 times
- krakatoa1883
Hi Franco, thanks, happy to read that you liked my images.
Raf
- pedro
- Has thanked: 14 times
- Been thanked: 6691 times
- Been thanked: 10489 times
Great set of captures Raf!
- marios i.
- Has thanked: 1707 times
- Been thanked: 1125 times
Wonderful images
Marios
Marios
Marios S.Ioannou
Sketcher/Visual Observer
- krakatoa1883
Thanks to all for your kind words, I am still undecided whether to buy or not a DS module, it costs a lot of money and I don't know if it's worth it...
Raf
I like the DS module.
- Has thanked: 8559 times
- Been thanked: 8290 times
Nicely done. Lovely FDs, Raf.
