Large filament on June 25
gabrieli
Been thanked: 1735 times
Post by gabrieli »
Taken with a Lunt152 in a clear sky with poor seeing conditions.
I had a curious experience with Autostakkert 3. Usually after going through the Analyze step, all the frames are arranged from best to worst from which you stack the best specified range of frames. I ran through 10 avi files before I realized, A3 was not doing this and that the frames were not ordered. I went back to Autostakkert 2.6.8 until I figure out what the problem was.
Lou
Has thanked: 9327 times
Been thanked: 6163 times
Re: Large filament on June 25
Post by ffellah »
That is one beautiful image, Lou !
eroel
Been thanked: 4981 times
Post by eroel »
Lou:
A very detailed image.
Has thanked: 17974 times
Been thanked: 8907 times
Absolutely terrific images :bow :bow
Interesting about ASK3, did you try stacking the best 10% and comparing it anyway? did it make a difference or was it just showing it differently? I think I might look at mine as I had a clearly good video and the output from even 2% was totally blurred. I can never close ASK3 down, I have to use task manager to switch it off and that annoys me.
marios i.
Has thanked: 1707 times
Been thanked: 1125 times
Post by marios i. »
Wow..
Marios
Marios S.Ioannou
Sketcher/Visual Observer
Ewan
Has thanked: 13 times
Been thanked: 41 times
Post by Ewan »
Montana wrote: Wed Jun 27, 2018 11:12 am Absolutely terrific images :bow :bow
Alexandra right click on AS!3 & change the compatibility to 'Run this program as an administrator' that should sort it, I had the same thing.
Ewan
Post by Ewan »
Very nice Gabrieli, looks just like I saw it, well done.
gabrieli
Post by gabrieli »
Hi, Alexandra
I didn't do the comparison you described, but I noticed that
1. after scrolling through the frames after "Analyze" they seemed to be in a random quality order, sometimes with obviously better frames after bad ones.
2. the stacked image had a definite blur to it and then
3. after using identical settings with AS2, the final stacked product was noticeably sharper than with AS3.
I'll try AS3 again after the next outing.
Lou
Thanks guys for the info, when I get a chance I will give all these tips a try.
FlankerOneTwo
Post by FlankerOneTwo »
I'm curious about the AS!3 issue and have been wondering how it orders the frames for display if "local" quality estimation is used - since the quality is calculated at each alignment point, it would seem that the order of frames would (potentially) be different depending which alignment point was being used. Does it sort by a global estimate? If so, seems like that might be potentially confusing regarding which frames are used for a specific alignment point.
Not sure how to explain the better results with AS2, I haven't used it so am not familiar with it, although I believe that the Laplacian quality estimator was new for AS3. Have you tried turning that off in AS3?
Has thanked: 156 times
Been thanked: 893 times
Post by Valery »
FlankerOneTwo wrote: Thu Jun 28, 2018 7:47 am I'm curious about the AS!3 issue and have been wondering how it orders the frames for display if "local" quality estimation is used - since the quality is calculated at each alignment point, it would seem that the order of frames would (potentially) be different depending which alignment point was being used. Does it sort by a global estimate? If so, seems like that might be potentially confusing regarding which frames are used for a specific alignment point.
There is a check on/off for global or local.
FlankerOneTwo
Valery wrote: Fri Jun 29, 2018 5:11 am
Right - I usually use the "local" setting. So if quality is computed at each alignment point, what determines which is the "highest quality" frame in the quality ordered list? Is it a composite score, e.g. sum of all individual AP scores, average AP score, or some other globally computed score? Each alignment point in principle has a different ordering of frames based on quality at that point. I was wondering if perhaps AS!3 does not re-order the frames if "local" is selected as a possible explanation for the OP's observation.
