Not posted for a while mainly due to weather & lack of activity, doing the house up doesn't help either but needs must
Managed a few captures yesterday with fairly good seeing allowing the 152mm to stretch it's legs a little.
26-06-2018 Various captures.
152mm TecnoSky, 135mm Baader, Daystar Quark Chromosphere, PG IMX174 on AZEQ6-GT.
Apologies for all the prom shots, i was running tests on Gamma Exp settings but thought they showed some nice detail.
Best 30-40% stacked in AS!3, sharpened in IMPPG.
Atb & clear skies
26-06-2018 Daystar Quark captures
- Has thanked: 13 times
- Been thanked: 41 times
- Surface & Prom.png (789.43 KiB) Viewed 1229 times
- Small Active area.png (2.08 MiB) Viewed 1229 times
- Prom 8.png (791.41 KiB) Viewed 1229 times
- Prom 7.png (794.79 KiB) Viewed 1229 times
- Prom 6.png (831.93 KiB) Viewed 1229 times
- Prom 5.png (789.43 KiB) Viewed 1229 times
- Prom 4.png (826.69 KiB) Viewed 1229 times
- Prom 3.png (806.43 KiB) Viewed 1229 times
- Prom 2.png (811.54 KiB) Viewed 1229 times
- Prom 1.png (838.45 KiB) Viewed 1229 times
- Pane 1.png (2.21 MiB) Viewed 1229 times
- Active Region 2.png (1.36 MiB) Viewed 1229 times
- Has thanked: 20803 times
- Been thanked: 10478 times
Re: 26-06-2018 Daystar Quark captures
These came out well Ewan!
- Been thanked: 1735 times
Hi, Ewan
There is some nice detail in the proms and I know you had to push the settings up a bit.
The surface detail shows care and restraint in processing where you sharpened just enough for the detail but not so much that artifacts show.
They do show a character similar to some of my recent images with my Lunt152 also with a Quark Chromosphere.
Great work.
Lou
Great work.
Lou
- Has thanked: 8558 times
- Been thanked: 8288 times
Good set of images, Ewan. Lots of nice detail in both the proms and chromosphere.
Wow!! these are beautiful! perfect in every way
We have had so many perfect mornings this week, if only I wasn't at work, we need these mornings at weekends
Thanks for the tips on ASK3, I will give it a try. I think my problem file at 5GB is too big to send even by WeTransfer (2GB limit), never mind.
- Been thanked: 4978 times
