Solar finder woes
denababy
Been thanked: 17 times
Solar finder woes
Post by denababy »
Hi everyone I have finally ordered a Quark chromosphere and waiting for it to arrive so in the meantime I am looking for a Solar finder to put onto my Explore Scientific scope. The problem is that the scope has an unusual foot, that, I think can be changed. I contacted the shop where I originally got the scope in the hope they would be able to help but either I talk in a foreign language or something but as yet I have not had one useful answer. There are no Astonomy shops in Leicester uk and as I am nearly deaf I have to do everything by email. Can anyone help please please please.
Has thanked: 1188 times
Been thanked: 1382 times
Re: Solar finder woes
Post by MalVeauX »
I use these:
http://www.dynapod.com/dyna-hp1.html
They just strap on, and you're good to go.
denababy
Post by denababy »
Thanks Marty do you know where I can get one in the UK?
Post by MalVeauX »
I don't; but it looks like they ship international and are still cheaper than a basic Sol Finder. I have a televue sol finder and the helio-pod. I use both. They work the same. The Helio-pod can go on all my scopes though, so I use it the most.
You can also just put a solar film filter in front of a finder scope that is already aligned on your scope. I do this too.
Here's the helio-pod on my 120mm, and if you look at the 40mm finder scope on its back, it has a small 50mm solar film filter on it, so I can just look through that and get a good wide field of view and center up on the sun. I use the helio-pod simply to point in the right direction, then I look through the solar film filtered finder scope to center up with the big scope (which operates at 4200mm when I image/view). Next to it, a televue Sol finder is held onto that 80mm scope with a rubber band. Does the job either way. I prefer the helio-pod for simplicity as it was designed to be banded on like that. Ultimately though I have to have a finder scope with a solar film filter because my big scope is way too long to attempt to find the sun without it.
pedro
Has thanked: 14 times
Been thanked: 6691 times
Post by pedro »
I have a FLICKR album that includes a few solar finders:
https://www.flickr.com/photos/pedro_re/ ... 3388014205
Imagetaka_fs60_solar_20160213-04 by Pedro Ré, on Flickr
Homemade solar finder
Imagestar_adventurer_sun_20180616-016 by Pedro Ré, on Flickr
Imagesol_searcherTV-01 by Pedro Ré, on Flickr
Sol Searcher
Imagesolar_imaging_session_20180216-052 by Pedro Ré, on Flickr
Sol Searcher
denababy
Post by denababy »
It has been quite a while since I started this post so here is an update. I purchased a Daystar Quark along with a Baader uv/ir filter (2”) and as suggested by Marty, a hello-pod, I am waiting for delivery of everything but when they arrive I will be able to use my Explore Scientific 80mm scope, in the meantime I have been collecting data with my Lunt 50 ready to do some processing when the weather is not as good in the uk as it has been for nearly 5 weeks, in Leicester that is.
You never know I may post some pics when I consider there is anything I consider worth showing.
Ewan
Has thanked: 13 times
Been thanked: 41 times
Post by Ewan »
Personally I have never had the need for a solar finder, once my ERF is on I slew to roughly where the sun is & then slew slowly until I get a nice red disc from the rear showing on my hand, connect the Quark & it's good to go ;-)
Good luck with your new solar set up I am sure you will enjoy it.
Atb
