High Res of the surface activity at the MINI-level with a Quark alternative.
Post by Valery » Wed Jul 04, 2018 3:45 pm
Hi here,
These days with a quiet and almost bald sun I continue to test a new "eyepiece form" H-a filter (similar in size to a Quark) . This H-a filter allows to use virtually any telescope with F/7 and slower (F/10 is the optimum). For a bigger than 70mm size a full size DERF filter is required. The filter allows very fast change of it's cental wave length and easily see a doppler effect on dark filaments and prominences.
Today I tested this filter with my C11 telescope equipped with full size 295mm DERF filter.
On the two images you can see that at a large scale ( telescopes 6" and up required) one always can find solar activity. Small dark filaments, mini-size active areas AR mini-flares, hot spots. Mini AR on the first image. On the second image is a small dark filament (prominence projected at the disk) and several short living hot spots at the roots of spiculaes.
The system worked at F/45 with a 0,6x reducer and Basler 1920-155 IMX174 camera. Final images were downsized to about 90%.
Thanks for looking.
Comments are welcome.
PDB
Re: High Res of the surface activity at the MINI-level with a Quark alternative.
Post by PDB » Wed Jul 04, 2018 5:33 pm
As usual these captures are outstanding.
Think you made many of us curious now about this alternative etalon. I suppose you are bound to some disclosure about this etalon while testing it. But it looks promising.
p_zetner
Post by p_zetner » Wed Jul 04, 2018 6:20 pm
Hi Valery.
Your new filter is certainly capable of some superb imaging! These images look to have a bandpass of 0.4A or less and I don't think I can see any "print through" of the photospheric granulation (maybe a hint of it?). Are you developing this for the market? If so, hopefully you'd have the etalon available without any associated optics?
Cheers, Peter.
Post by Valery » Thu Jul 05, 2018 1:39 am
Hi Valery.
Cheers, Peter.
Hi Peter,
After the etalon itself, the key is all associated optics and a correct mechanics. This is a kit. This is for peoples who are tired of a non-uniformity and too long time required to jump between different CWLs. And this keit is not expensive!
Post by Montana » Fri Jul 06, 2018 9:11 am
Some really beautiful images again Valery :bow
Users browsing this forum: Bing [Bot] and 2 guests
