Sol from the 4th of July 2018.
eroel
Post by eroel » Wed Jul 04, 2018 10:45 pm
Hi:
Clouds and rain most of the time, but before lunch I had an opportunity to see the sun through haze and clouds running, so took the CaK and Ha FD´s with the 102mm f/9 Meade with a CaK PST mod and in Ha with the Solarmax 90-DS.
Thanks for looking.
Sol del 4 de julio de 2018-Meade-CaK-PSTmod-1an.jpg (892.67 KiB) Viewed 370 times
Sol del 4 de julio de 2018-Meade-CaK-PSTmod-1inv.jpg (966.38 KiB) Viewed 370 times
Sol del 4 de julio de 2018-Meade-CaK-PSTmod-2an.jpg (823.65 KiB) Viewed 370 times
Sol del 4 de julio de 2018-Meade-CaK-PSTmod-2inv.jpg (864.5 KiB) Viewed 370 times
Sol del 4 de julio de 2018-Solarmax 90-DS-BF30-1an.jpg (834.39 KiB) Viewed 370 times
Sol del 4 de julio de 2018-Solarmax 90-DS-BF30-1inv.jpg (868.08 KiB) Viewed 370 times
Sol del 4 de julio de 2018-Solarmax 90-DS-BF30-2an.jpg (937.8 KiB) Viewed 370 times
Sol del 4 de julio de 2018-Solarmax 90-DS-BF30-2inv.jpg (993.85 KiB) Viewed 370 times
DJD
Re: Sol from the 4th of July 2018.
Post by DJD » Thu Jul 05, 2018 8:44 am
Lovely images Eric.
What technique do you use to superimpose the bright proms ?
David
banjo
Post by banjo » Thu Jul 05, 2018 9:35 am
:bow :bow very beautiful series, Eric .
the last is superb.
Paul
bresser/messier 150/1200 Mod -D-Erf 160mm intern-glasspath 1.25-etalon Pst barlow X2 ASI174
http://astropol.pagesperso-orange.fr/soleilbis/soleilen
Ibbo
Post by Ibbo » Thu Jul 05, 2018 11:09 pm
Good discs Eric
eroel
Post by eroel » Thu Jul 05, 2018 11:48 pm
David, Paul and Steve:
Thanks for looking and commenting, much appreciated.
David, I use PS and load the finished "surface" frame and the "prominence" frame, then use the magic wand on the "Surface" one, then SELECT/inverse/then Modify/smooth/feather and then EDIT/copy.(you have to try which parameters to use for smooth and feather (I use 3 pixels and 0.8 pixel)
Then I go to the prominence image and use IMAGE/image size and make it a bit smaller until it fits by trial and error using EDIT/paste.(move the "Surface" image with the the Move Tool, so to fit it to the "prominence" frame.
When you like the fit,use LAYER/flatten image and crop it (with the Crop Tool) and save it and that is all.
Hope it is understandable, if not just let me know.
DJD
Post by DJD » Fri Jul 06, 2018 6:28 am
Thanks Eric, perfectly clear. I will give it a whirl.
David
Post by Montana » Fri Jul 06, 2018 11:21 am
Terrific shots again Eric :bow
Users browsing this forum: Giorgio and 6 guests
