High resolution images of the granulation with the 300 mm solar scope : from red light to violet (G band)
christian viladrich
Has thanked: 1 time
Been thanked: 2725 times
Post by christian viladrich »
Dear All,
I was nearly one year since the last time I use my 300 mm solar telescope.
Last Saturday morning, the conditions were not very promising. The wind came from Nord-West, which usually is not good for the seeing. And the sky was coronal, which is not good either. On top of that there was not a single spot or even a small pore in view.
Having re-collimated the scope during the previous night, I decided to give it a try anyway just to check my collimation on the Sun.
I started with a red filter (656 nm), then switch to a green filter (540 nm), to a blue/green filter (500 nm) and finally to the 430 nm (G band filter).
Accordingly, this sequence shows the increase of contrast and resolution when going from red to violet light.
Here are the images.
Red light (656 nm), the contrast is prety low, but this filter is less sensitive to the seeing :
Green light (540 nm), the contrast is much better :
Green/blue light (500 nm), the contrast and resolution are still better. Usually, this is the optimal filter for my place :
G band (430 nm). This one is a different world since the intergranular bright spots and filigrees become visible. This is the first time ever I have these seeing conditions at my place :-)
Best regards
Last edited by christian viladrich on Mon Jul 09, 2018 7:21 pm, edited 1 time in total.
MalVeauX
Has thanked: 1179 times
Been thanked: 1369 times
Re: High resolution images of the granulation with the 300 mm solar scope : from red light to violet (G band)
Post by MalVeauX »
Awesome cells! And the comparison of filters is really helpful!
eroel
Been thanked: 4957 times
Post by eroel »
Christian:
Superb high resolution images.
Has thanked: 9280 times
Been thanked: 6127 times
Post by ffellah »
Fantastic granulations, Christian.
Has thanked: 64 times
Been thanked: 4407 times
Post by MapleRidge »
These images are excellent no matter what filter is chosen Christian...superb work :bow
Has thanked: 17901 times
Been thanked: 8888 times
My!!!!! I wish I had seeing like that, I don't have a hope. These are absolutely gorgeous :bow :bow :bow
robert
Has thanked: 4 times
Been thanked: 1275 times
Post by robert »
Wonderful (all of them). Very useful to have the comparison to refer too as well. Thanks for that.
Brilliant!
Robert
Valtori
Has thanked: 312 times
Been thanked: 182 times
Post by Valtori »
The brilliant granulation shots!!
Val
Has thanked: 156 times
Been thanked: 893 times
Post by Valery »
Hi Christian,
I am very impressed with the G-band image. Other are quite nice too, but the G-band is something special.
pedro
Has thanked: 14 times
Been thanked: 6683 times
Post by pedro »
AMAZING resolution Christian. Brilliant, I'm speechless
I noticed that you combined more images this time (15 to 30 images)
christian viladrich
Has thanked: 1 time
Thanks to all :-)
Valery : I agree with you, the G band image has something of its own. The granulation cells are very diffentiated with different levels of shades.
Pedro : you've got a keen eye ;-) The seeing was really oustanding for these images. Even better than what we experienced last August at St Veran observatory (2930m). This made it possible to stack more images.
p_zetner
Has thanked: 166 times
Been thanked: 719 times
Post by p_zetner »
What an impressive set of images, Christian. I find it a bit difficult to differentiate the 540nm and 500nm images as far as contrast is concerned. They both look amazingly crisp. I agree with Valery. The G band image is terrific with many bright points visible. Wonderful!
Cheers, Peter.
christian viladrich
Has thanked: 1 time
Thanks Peter,
I have updated the 500 and 540 nm images. Now, the processing of both images is consistent. In the previous version, I had applied a more agressive filter to the 540 nm image, which resulted in a reduction of the difference between both images.
Post by Valery »
Hi Christian,
Your white light images are so noise-fee, unbelieveably noise-free. Do you use any special de-noising software?
I tried white ligth imaging many times include under a very good seeing. Tried de-noising in PS CS6, Topaz. Not even close to what your images are.
Thanks,
christian viladrich
Has thanked: 1 time
Hi Valery,
The processing for photopheric images is very simple. I just apply an unsharp mask (sigma = 1.4 pixel, k = 8). Nothing else.
Best regards
Christian
Has thanked: 20738 times
Been thanked: 10432 times
Exceptional images Christian and an excellent comparison!
Post by Valery »
christian viladrich wrote: Tue Jul 10, 2018 3:10 pm
Hi Christian,
Thanks for the tip. I will try it with my images.
To understand how good can be the images for such a simple processing, can you, please, show us here the unsharpened stacked image and one of the staked frames (an individual single frame).
Do you use a more complicated processing for CaK and H-a images?
Thanks,
I think this is just outatnding raw data in the first place Valery
banjo
Has thanked: 2098 times
Been thanked: 2870 times
Post by banjo »
superbe Christian , bravo !!!!
:bow :bow :bow :bow :bow :bow :bow :bow
Paul
Post by Valery »
marktownley wrote: Wed Jul 11, 2018 11:16 am I think this is just outatnding raw data in the first place Valery
Yes, I agree. But what is a miracle for me is that I have no problems with CaK data processing and Ha data. Not so easy with continuum data.
So, I would like to understand how to process the continuum raw images maximally effectively - minimal noise with delicate shades.
And this G-band image looks like etalon for photospheric features imaging. We can do a little against the seeing, but we can do different processing!
