High resolution images of the granulation with the 300 mm solar scope : from red light to violet (G band)
christian viladrich
Post by christian viladrich » Sun Jul 08, 2018 9:26 pm
Dear All,
I was nearly one year since the last time I use my 300 mm solar telescope.
Last Saturday morning, the conditions were not very promising. The wind came from Nord-West, which usually is not good for the seeing. And the sky was coronal, which is not good either. On top of that there was not a single spot or even a small pore in view.
Having re-collimated the scope during the previous night, I decided to give it a try anyway just to check my collimation on the Sun.
I started with a red filter (656 nm), then switch to a green filter (540 nm), to a blue/green filter (500 nm) and finally to the 430 nm (G band filter).
Accordingly, this sequence shows the increase of contrast and resolution when going from red to violet light.
Here are the images.
Red light (656 nm), the contrast is prety low, but this filter is less sensitive to the seeing :
Green light (540 nm), the contrast is much better :
Green/blue light (500 nm), the contrast and resolution are still better. Usually, this is the optimal filter for my place :
G band (430 nm). This one is a different world since the intergranular bright spots and filigrees become visible. This is the first time ever I have these seeing conditions at my place :-)
Best regards
Last edited by christian viladrich on Mon Jul 09, 2018 7:21 pm, edited 1 time in total.
http://www.astroplanetes.com/
Re: High resolution images of the granulation with the 300 mm solar scope : from red light to violet (G band)
Post by MalVeauX » Sun Jul 08, 2018 10:13 pm
Awesome cells! And the comparison of filters is really helpful!
Post by eroel » Sun Jul 08, 2018 10:24 pm
Christian:
Superb high resolution images.
Post by ffellah » Sun Jul 08, 2018 11:57 pm
Fantastic granulations, Christian.
Post by MapleRidge » Mon Jul 09, 2018 1:07 am
These images are excellent no matter what filter is chosen Christian...superb work :bow
Post by Montana » Mon Jul 09, 2018 9:20 am
My!!!!! I wish I had seeing like that, I don't have a hope. These are absolutely gorgeous :bow :bow :bow
robert
Post by robert » Mon Jul 09, 2018 1:37 pm
Wonderful (all of them). Very useful to have the comparison to refer too as well. Thanks for that.
Brilliant!
Robert
2018 images https://www.flickr.com/photos/69734017@ ... 1234171714
Valtori
Post by Valtori » Mon Jul 09, 2018 1:53 pm
The brilliant granulation shots!!
Val
Post by Valery » Mon Jul 09, 2018 2:06 pm
Hi Christian,
I am very impressed with the G-band image. Other are quite nice too, but the G-band is something special.
christian viladrich
Post by christian viladrich » Mon Jul 09, 2018 7:28 pm
Thanks to all :-)
Valery : I agree with you, the G band image has something of its own. The granulation cells are very diffentiated with different levels of shades.
Pedro : you've got a keen eye ;-) The seeing was really oustanding for these images. Even better than what we experienced last August at St Veran observatory (2930m). This made it possible to stack more images.
p_zetner
Post by p_zetner » Mon Jul 09, 2018 11:24 pm
What an impressive set of images, Christian. I find it a bit difficult to differentiate the 540nm and 500nm images as far as contrast is concerned. They both look amazingly crisp. I agree with Valery. The G band image is terrific with many bright points visible. Wonderful!
Cheers, Peter.
christian viladrich
Post by christian viladrich » Tue Jul 10, 2018 9:51 am
Thanks Peter,
I have updated the 500 and 540 nm images. Now, the processing of both images is consistent. In the previous version, I had applied a more agressive filter to the 540 nm image, which resulted in a reduction of the difference between both images.
Post by Valery » Tue Jul 10, 2018 1:55 pm
Hi Christian,
Your white light images are so noise-fee, unbelieveably noise-free. Do you use any special de-noising software?
I tried white ligth imaging many times include under a very good seeing. Tried de-noising in PS CS6, Topaz. Not even close to what your images are.
christian viladrich
Post by christian viladrich » Tue Jul 10, 2018 3:10 pm
Hi Valery,
The processing for photopheric images is very simple. I just apply an unsharp mask (sigma = 1.4 pixel, k = 8). Nothing else.
Best regards
Christian
Post by marktownley » Wed Jul 11, 2018 4:31 am
Exceptional images Christian and an excellent comparison!
Post by Valery » Wed Jul 11, 2018 7:01 am
Hi Christian,
Thanks for the tip. I will try it with my images.
To understand how good can be the images for such a simple processing, can you, please, show us here the unsharpened stacked image and one of the staked frames (an individual single frame).
Do you use a more complicated processing for CaK and H-a images?
Post by marktownley » Wed Jul 11, 2018 11:16 am
I think this is just outatnding raw data in the first place Valery
banjo
Post by banjo » Wed Jul 11, 2018 11:50 am
superbe Christian , bravo !!!!
:bow :bow :bow :bow :bow :bow :bow :bow
bresser/messier 150/1200 Mod -D-Erf 160mm intern-glasspath 1.25-etalon Pst barlow X2 ASI174
http://astropol.pagesperso-orange.fr/soleilbis/soleilen
sorry for my English translators google :mrgreen:
Post by Valery » Wed Jul 11, 2018 1:21 pm
Yes, I agree. But what is a miracle for me is that I have no problems with CaK data processing and Ha data. Not so easy with continuum data.
So, I would like to understand how to process the continuum raw images maximally effectively - minimal noise with delicate shades.
And this G-band image looks like etalon for photospheric features imaging. We can do a little against the seeing, but we can do different processing!
Users browsing this forum: No registered users and 4 guests
