July 7th - Ha
- Has thanked: 65 times
- Been thanked: 4459 times
July 7th - Ha
Hi everyone...
I had a brief amount of time on Saturday to grab some images, but the seeing was poor so I limited the session to a few full disk images and cut attempts to do any higher resolution work based on how things shaped up on the monitor when I set up on the CR150.
The images below are a composite disk and limb exposure, with the limb layer inverted to enhance the small, faint proms on the eastern limb. These were taken through the LS80T/B1200Ha/LS75FHa double stack system: With the new suspected AR starting to round the limb I was hoping to get more images but seeing limited me to these...both through the CR-150/DSSII/B1800Ha modded scope and a 2x tele-extender. The first had the pressure tuner of the DSII set a 0PSI which acted like a red filter (WL), while the second was set at 17PSI to put it on band for Ha: I also cut the session short as I found the etalon wasn't properly aligned and I had to dismantle the modded setup and re-build it...which seemed to fix the issue but used up my time so I closed up for the day.
- Has thanked: 9383 times
- Been thanked: 6199 times
- Has thanked: 20940 times
- Been thanked: 10587 times
Re: July 7th - Ha
Good shots! The new active region seems more of a decaying old one to me...
- DJD
- Has thanked: 42 times
- Been thanked: 133 times
Re: July 7th - Ha
Brian,
I always like your full disks. Can I ask what was wrong with your etalon? How did it become misaligned and how did you correct it ?
Best wishes,
David
Best wishes,
David
- Has thanked: 18101 times
- Been thanked: 8939 times
Re: July 7th - Ha
Yes, I agree, I think this big AR is very decayed and holds no sunspots. Just pretty in CaK and Halpha for the plage disturbances. Some lovely images Brian
Re: July 7th - Ha
Franco, Mark, David, and Alexandra...
Thanks to each of you for your comments and feedback, it is always appreciated
David, I had removed the DSII etalon from my modded setup to test out a few things, but when I reassembled it I had not seated properly in the holder and since it wasn't square to the optical axis it wouldn't tune.
- marios i.
- Has thanked: 1707 times
- Been thanked: 1125 times
Re: July 7th - Ha
Very nice!
Marios
Marios
Marios S.Ioannou
Sketcher/Visual Observer
- Been thanked: 5015 times
Re: July 7th - Ha
Brian:
A very good session considering the seeing conditions.
Have a nice weekend,
Re: July 7th - Ha
Derek, Marios, and Eric...
Thanks for your comments!!!
- Has thanked: 8588 times
- Been thanked: 8324 times
Re: July 7th - Ha
Nice images, Brian. Now a few days on, the disturbed plage looks pretty impressive.
Hope you get your equipment back up to par shortly.
