AR from July 12
p_zetner
Has thanked: 166 times
Been thanked: 719 times
AR from July 12
Post by p_zetner »
Greetings Everyone.
Some views of the current AR at two different image scales.
(Please excuse the dust mote on the higher magnification image. I didn't flat-field this one and don't have access to Photoshop at the moment!)
Cheers, Peter.
p_zetner
Re: AR from July 12
Post by p_zetner »
Also, a very small AR near the W limb that seems to have disappeared.
I just discovered this as seeing started to seriously degrade so the imaging was pretty bad.
Cheers, Peter.
eroel
Been thanked: 4957 times
Re: AR from July 12
Post by eroel »
Peter:
Very very good images with your 8" scope, you are getting better shots every day.
I am anxious to start using my 10" f/20 Maksutov with an Aries ERF, but weather and compromises during weekends have not let me go to the rural observatory.
Have a nice and sunny weekend,
Has thanked: 8523 times
Been thanked: 8253 times
Re: AR from July 12
Post by Carbon60 »
Nice images, Peter. Getting better and better.
Has thanked: 9294 times
Been thanked: 6129 times
Re: AR from July 12
Post by ffellah »
Beautiful, sharp looking images, Peter !
Has thanked: 20743 times
Been thanked: 10439 times
Re: AR from July 12
Very good Peter! The flat field function in firecapture works great for close in shots like these, all you need is some plastic film big enough to cover the aperture of the scope.
Has thanked: 156 times
Been thanked: 893 times
Re: AR from July 12
Post by Valery »
Nice images, Peter
I think that the middle scale between the two shown will be the best compromise details/sharpness wise.
p_zetner
Re: AR from July 12
Post by p_zetner »
Thank you for your comments, everyone.
Eric: I hope you get the chance soon to try your 10" Mak. I look forward to seeing images from this instrument.
Stu: I'm totally impressed by the granulation shots with your 250mm RCT. Hope you have some luck with H alpha.
Mark: I flat-field the images involving my focal reducer because there is a hot spot present in the field of view. The field homogeneity without focal reduction is quite good but, of course, doesn't solve the dust bunny problem! Flats next time.
Valery: Good advice! This was a rather large structure. I'll have to experiment with slightly different FR design to get around f35 - f40 at the camera.
I'm back at my Photoshop equipped computer so can remove the obnoxious dust spot. Here is the result of the high magnification image with slightly different (better?) processing.
Cheers, Peter.
Has thanked: 17925 times
Been thanked: 8892 times
Re: AR from July 12
These are really nice Peter :bow
p_zetner
Re: AR from July 12
Post by p_zetner »
Thanks very much, Alexandra. Still experimenting with processing!
Cheers, Peter.
