The usual websites tell me the sun is blank, well that just depends what wavelength you're looking in. The active region mid disk has plenty going on, just no sunspots. Given it is possible to see the magnetic field lines in the plasma indicating 2 poles the lack of spots means the field strength is less than 1500 Gauss, generally accepted as the minimum for sunspot formation.
This double stacked view was taken with a Lunt50 etalon on the ED60 scope, stepping down to 50mm gives a nice f7 light cone which is then fed into the daystar Quark. The end result is a nice contrasty view. Camera used was the IMX249 chipped PGR.
ar-and-limb-bw by Mark Townley, on Flickr
ar-and-limb-colour by Mark Townley, on Flickr
ar-close-bw by Mark Townley, on Flickr
ar-close-colour by Mark Townley, on Flickr
Given i'm running at just 50mm aperture i'm pretty pleased with the results.
Hope you like.
The Blank Sun? 14th July
- Been thanked: 10488 times
- DJD
- Has thanked: 42 times
- Been thanked: 133 times
Re: The Blank Sun? 14th July
They are excellent Mark.
David
David
Excellent images, Markmarktownley wrote: ↑Sat Jul 14, 2018 1:53 pm The usual websites tell me the sun is blank, well that just depends what wavelength you're looking in. The active region mid disk has plenty going on, just no sunspots.
Too bad you didn't make the image in the CaK line! CaK will be even more dramatic/impressive.
- pedro
- Has thanked: 14 times
- Been thanked: 6691 times
Great results Mark
I also did a few FD images during half time of the world cup match
Pedro Re'
- PDB
- Has thanked: 2 times
- Been thanked: 149 times
Hi Mark,
nice images. That area showed some small spots in WL en Solar Continuum. Made some images but they are not that good due to very bad seeing. Can't upload them now because I am doing some maintenance on my main computer.
Paul
Paul
- Been thanked: 4427 times
Great shots Mark
- Has thanked: 9319 times
- Been thanked: 6157 times
Thanks for your kind words everyone!
You certainly do get some lovely, clean and detailed images from the 50mm I could do with getting more out of my 40mm
