Good evening all...
I'm getting caught up on the imaging session and this post highlights the session form Sunday morning (July 15th). The day started with a crisp blue sky and decent seeing, but as the day progressed the temperatures moved well above 30C but I managed to finish at the scope before it got too hot.
There were fewer proms as previous days, but the detailed non-AR still dominated the view and like Valery I found a few dark spots in the red continuum (zero pressure on the DSII etalon). Starting off are the images taken through the LS80T/LS75FHa/B1200Ha solar scope, full disk and limb composites with the limb inverted:
The first images I grabbed through the modded CR-150/DSII/B1800Ha (with a 3x tele extender in front of the camera) had the tuner on the DSII unit set at 0 PSI. This managed to show a few small dark spots as Valery posted earlier as well a bit granulation and faculae in the areas that show in the tuned Ha images:
After being tuned, the scope was trained to the western limb to see if any potential activity was on the way into view. There was a subtle linear feature that I grabbed and after processing shows an X shaped filament feature:
The image below is a 2 frame mosaic of the eastern limb:
The last image is a 2 frame mosaic that covert he region of activity, now well to the west of mid disk:
There were four main areas with proms, presented below moving clockwise around the limb from the NW quadrant:
This concludes the last session I had on Sunday. As always, questions and comments are always welcome.
More Ha from July 15th
- Been thanked: 4340 times
- Has thanked: 20424 times
- Been thanked: 10242 times
Re: More Ha from July 15th
A lovely set of images there Brian. The X is ex-active region AR12715.
Hi Mark...
Thanks for your feedback on the images , and for the ID in the returning AR.
- Has thanked: 17648 times
- Been thanked: 8787 times
Some lovely ones there Brian, well done in getting those tiny pores I think the last AR close up pic is my favourite
- Been thanked: 4904 times
Brian:
Looks like you had a very interesting session, beautiful proms.
- Has thanked: 8415 times
- Been thanked: 8161 times
Great images, Brian, and an excellent session.
Alexandra, Eric, and Stu...
My thanks to each of you for your comments and feedback...much appreciated
- Has thanked: 9143 times
- Been thanked: 6024 times
A very nice collection, Brian ! Fine views of the active region...
Thanks Franco!!!
